Battery opinions? |
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Nov 2021 at 1:44pm |
I have a 2012 Dodge Durango with the original battery, going in to ND winter do you think I should replace it before real cold? Just would like others thought on this. I think good service out of a 10 year old battery.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4107 |
Yes!
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10973 |
YEP |
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
I would have it load tested, new one may not be any better than the 10 year old OEM. I have a 2006 jeep that still has its original and going well. Batteries are available around me within a day, very expensive though for good ones. JMO
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12234 |
10 years is a good run. I guess it depends on if money is tight, and who drives it with the what possibility of getting stranded where.....I'd change it since you're thinking of it.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88290 |
I change out at 7 years.. if it lasts that long.
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1589 |
I had to replace 2 in the last week, both were 8 years old. My 2014 Silverado's original Delco died at work, I knew she was on the decline but pushed it a little to far. 790 CCA Deka at 149 bucks. 2 days later my 2005 2500 HD's Exide battery died in the garage with no warning, bought an 800 CCA Interstate for that one at 150 bucks, also 8 years old. When it rains it pours as they say.
Edited by AllisFreak MN - 02 Nov 2021 at 6:36pm |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34227 |
Hang on to your skirts boys as replace the OE Batteries. New batteries 99% of manufactured are 'Recycled' lead from old batteries. Average lifespan on these is Just off Warranty time or close to five years.
klinemar ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Michigan Points: 8060 |
I had a loose connection in my Round Baler's electric controls that would draw the batteries in my 7060 down if I forgot to unplug. I forgot and both batteries would not hold a charge. So that replacement was $300 and change. And since it has rained all summer I had time to find the loose connection in the relay! The batteries I replaced were 7 years old. Some batteries last longer than others in my experience.
iowallis ![]() Silver Level ![]() Joined: 04 Jun 2017 Location: North Iowa Points: 372 |
Got 12 years out of the factory battery in my Dakota. Just kept a fully charged battery (from one of my old cars) in the tool box in the bed for 3 winters knowing it could die at anytime. One night after bowling it turned over slowly and then nothing. Jumped it with the spare battery, then I knew I got the most out of it. The replacement, a Mills Fleet Farm store brand (RoadRunner?) lasted 7 before that one needed to be replaced.
Aftermarket batteries are a gamble. The Advanced Auto "Silver" in my '59 Chevy is going on 14 years, knock on wood. 2 high end Oreilly's with 36 month free replacement in my '82 Lebaron lasted 2 years before they needed to be replaced. The 3rd one is 4 years old.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
One of those 'pay me now, or pay me later' deals....but..it WILL fail you Murphy says...probably on a cold, windy, sleety night when you MUST go somewhere... Buy a new one, keep the old, inside a warm place on a maintainer. I'd actually see if you could add a 2nd battery into your ride,identical batteries with a solenoid to power starter from 2nd battery and first. I KNOW my AC forklift with BUDA BS153 loves the 2nd battery !
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
jim, now that is a question that if you don't want to know the answer don't ask it. Since I am spending your money, you better replace it.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
I would at least have a new one on hand. ---- this might be a super cold winter and even tho some of the good ones last 7 to 8 years, when they go,-- they usually go without warning. I always carry my jumper pack with me all the time!-- I dont trust the new ones either!
baverwolf ![]() Orange Level ![]() Joined: 24 May 2010 Location: SE Montana Points: 828 |
I bought a pickup 19 years ago that had a brand new Wal-Mart battery in it. Didn't think it would last long but I got ten years out of it. So...I bought another...its got nine years on it but noticed on cold mornings its a bit slow so I'm pretty sure it will die this winter. I've had decent luck with the better Napa batteries in other equipment. Had real good luck with the Napa commercial 6 volt batteries. I had two I've gotten eleven years out of them. I do try to give everything a charge every so often in the off season. Also try to keep them topped off with distilled h20 on the ones that aren't maintenance free. I have not had good luck at all with interstate batteries. Seems they leak horribly at the terminals and only last about 5 years. Just my two cents..
Edited by baverwolf - 03 Nov 2021 at 5:29pm |
Thanks for al the input, I am going to replace it, not sure what with, will start checking tomorrow.
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6496 |
On my wife's, my daughter's and my g'daughter's vehicles I replace every 5 years and repurpose the old batteries to another use until they are used up. On my vehicles I swap out at 7 years. I buy my batteries from an independent dealer that only deals in batteries and know their stuff. I took in a battery out of our spare church van that I thought was shot but they charged it for 24 hours and it tested good and after 6 months still going. They are located out in the country and their main advertising is customer recommendations.
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Watched a guy on YouTube test several batteries and the Wal Mart battery tested as good or better than most but at a far cheaper price. That's what I'm running now 800CCA Had it load tested after a year and it showed 811CCA. Time will tell.
1957 WD45 dad's first AC
I've been getting Motorcraft batteries the last several years. A little pricier, but a much better warranty than the run of the mill replacement brands. Have worked many wonderfuls. Just my opinion, others including yours may vary.
Tad Wicks ![]() Orange Level ![]() ![]() Joined: 27 Mar 2011 Location: Shandon, CA Points: 2175 |
I don't know how you guys are getting that kind of time out of your batteries. I used to buy nothing but Interstate but they went downhill and the ones here don't have handles, Napa batteries are good but they don't have handles either, I have been buying Wal-Mart 5 year batteries, they will go the distance but not much more and they have a strap, very important when playing musical batteries. I had an 8D in my 11 that went 10 years, unheard of around here, that one I put a solar charger on, must have worked. The long and the short of it is I change batteries in the wife's car and the family car at 5 years and I feel as though I am flirting with a problem at that.
I hear ya Tad. Last Motorcraft I bought still had a good handle. They have been 8 year batteries. Trying to remember the wording of the warranty, but it's something like 5 year 100% replacement, then prorated the last 3? Maybe?
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1788 |
This is a scary subject for me. Every time I have a battery go bad here on the farm it turns into an epidemic.
Edited by sparky - 04 Nov 2021 at 11:21am |
Hey TBone, been quite awhile since we conversed, hope all is well and things are going your way
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4756 |
That seems the story of my life as well. ![]() ![]() ![]() When Kragon Auto parts was the big new in town chain and had $30 batteries advertised for 5 years, the warranty always got made out to my pickup and I put the paper where I could find them. Since I moved the dang things anyway from tractor to truck or what ever even the prorated part on the last 3 years made them a good deal.
I have been really lucky I guess. A fairly close neighbor owns the interstate district here and is a terrific guy. He gives me/or anybody really “good” load checked batteries that are returns if he has the size I need at the time in return for any core. Have gotten lots of service from others premature returned cores. He also generally keeps a pretty good stock of seconds which I have been satisfied with for a very low cost.
dee_veloper ![]() Orange Level ![]() Joined: 12 Apr 2021 Location: USA Points: 1168 |
I've had great success with Motorcraft batteries. First battery lasted about 12 years. Second battery is now about 6 years old. No problems with either.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
Update, I replaced my battery, went with an Interstate because that is what local dealer sells, have gotten many from him and had good luck, hopefully with this one too.
I have several Interstate Batteries in service right now... and a couple from Wal Mart... Doing very well for life.
matador ![]() Orange Level ![]() ![]() Joined: 10 Nov 2014 Location: Wyoming Points: 1727 |
I'd replace it, but then again on our farm, there's always something that could use an old battery like the one you'd be taking out
Tractors: Allis WD (x2), Allis 7040, Oliver 1800A Diesel, Case 830 Caseomatic, White 2-105, Massey 1105 | Plus a Gleaner F2, 30' A-C 1300 Cultivator, Flightline bale elevator
