battery cut-off switch on 190xt |
troy(el paso, il)
Topic: battery cut-off switch on 190xtPosted: 25 Mar 2017 at 8:25am |
Just wondering if any of the 190's had battery cut-off switches or safety switches from the factory, and if so, where were they mounted?.....
Thanks, Troy |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 25 Mar 2017 at 9:01am |
mine don't, but they can always be added to it
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2231 |
Posted: 25 Mar 2017 at 9:35am |
We have them on our combines, 8050's 8070, 7020 and both 200's. On the 200 we mounted to the front cowling where the side panel "used" to be, above the clutch pedal. Split the positive cable between battery and solenoid.
Leon B |
troy(el paso, il)
Posted: 25 Mar 2017 at 7:21pm |
Leon, that's about where I was thinking about putting one on my 190.....thanks.
Leon B MO
Posted: 25 Mar 2017 at 7:58pm |
I'll snap a picture in the morning (if I can remember).
Leon B |
troy(el paso, il)
Posted: 25 Mar 2017 at 8:41pm |
Leon, thanks! That would be great.....
Leon B MO
Posted: 27 Mar 2017 at 7:46pm |
Here ya go Troy. I forgot that on the everything except the 7020, I put the disconnect in the ground cable from the battery, That way if the switch or cable becomes defective, it would not be live.
Leon B MO
bauerd44
Silver Level Access
Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Posted: 27 Mar 2017 at 9:30pm |
Leon, Where did you get your switches?
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
troy(el paso, il)
Posted: 28 Mar 2017 at 6:08am |
Leon, many thanks for the pic.! So, you put the "original" ground cable on the switch and on the other side of the switch ran a "new" ground. Do you have two batteries on these tractors? Did you tie both of the grounds together and run them to the switch?
Leon B MO
Posted: 28 Mar 2017 at 8:22am |
Yes, 2 batteries, one cable from them through switch, back to housing. The switches came from some semi-truck service shop dad knows of in St. Louis. Amazon has them for about the same money. I think dad said he paid like $27 apiece.
Leon B Mo. |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 28 Mar 2017 at 9:56am |
We have em' in stock on our website if interested..
Steve@B&B |
troy(el paso, il)
Posted: 28 Mar 2017 at 10:16am |
Leon, thanks for the info. Going to give it a try...........Best, Troy.
DougG
Posted: 28 Mar 2017 at 4:30pm |
Just curious on why the negative cable?
DougS
Posted: 28 Mar 2017 at 4:57pm |
Safety. You can wrench all day on the grounded side of the battery and having your wrench accidentally touch the frame won't cause any nasty sparks. You can do the same on the hot terminal with the switch turned off. |
Leon B MO
Posted: 28 Mar 2017 at 8:50pm |
Yep, and if the switch fails or grounds out it simply goes to ground not "hot". The battery doesn't know the difference.
Leon B MO
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1260 |
Posted: 29 Mar 2017 at 5:59am |
I was always told, ground cable is always the first cable to take off and the last one to put on.
garr
Joined: 06 Apr 2013 Location: Chickamauga, Ga Points: 125 |
Posted: 29 Mar 2017 at 7:13am |
Harbor Freight has them for less than $10
Steve in NJ
Posted: 29 Mar 2017 at 10:38am |
Yeah, and its a get what ya pay for to! Chinese junk. Find yourself a Cole/Hersee, Grote, or Standard Ignition unit. Put a good one on it and forgetaboutit.
DougS
Posted: 29 Mar 2017 at 11:59am |
What Steve said.
