Battery corrosion on D19
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Topic: Battery corrosion on D19
    Posted: 4 hours 35 minutes ago at 7:55pm
So I have a D19 that I’ve switched to negative ground and it charges perfectly but for some reason I get an excessive amount of corrosion on the terminals,battery tray and below the tray on the side panels and anywhere there’s a bare spot where the paint is chipped,even the bolt heads. Any idea. Thanks in advance
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 5 minutes ago at 8:25pm
Probably not much. Clean everything up well. Use a weak baking soda solution to clean all the acid up and do that once or twice a year. Apparently negative ground systems are worse than positive ground for this problem. Also make sure you are not in an overcharge situation as that will make it worse - leakage at battery. Make sure the grounds are good and clean at both ends of the cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 50 minutes ago at 8:40pm
Thanks for the advice. I’ll give it a try
This page was generated in 0.067 seconds.
