Battery cables on AC 170 gas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Battery cables on AC 170 gas?
    Posted: 20 Jun 2022 at 10:22pm
Does anyone make a battery cable that is worth anything? Can't buy anything these days worth a crap.What is up with the cable ends anymore? Who makes good ones these days? Bad enough the trouble it is to put a battery in one of them. Tracy
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 11:50pm
Are going to solder or crimp?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 6:08am
If you want quality electrical parts of any kind, go to Brillman.
Udated address
Edited by PaulB - 21 Jun 2022 at 8:39am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 7:26am
   https works better !
https://brillman.com/
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 9:35am
I buy cable and ends in bulk and make my own. Have since the early 70's.
  Most gas engines get #1 gauge cable and Diesel engines get #00 cable.
  I solder ends on and heat shrink them. I buy cable in both RED and BLACK, but as cost per foot has really jumped likely to just buy Black next time. #00 is about $5.50/ foot wholesale now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 12:52pm
Wire diameter for different "gauge" size..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 4:59pm
Ron, crimp and solder. Heat shrink the ends that matter. Thanks, Tracy
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2022 at 8:05am
I get mine at the local JD shop they make them up from quality cable and ends use a hydraulic crimper I've never in 20 years had one go bad or lose connection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2022 at 8:45pm
I use 00 and get quality crimp ends. I have a crimp tool that does multiple sizes so I can do small wiring on up to the bigger stuff. Has worked well for me. Big difference using wielding cable. My 6V WD spins over much faster with the 00.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2022 at 9:02pm
I make all kinds of different cables in the shop. Truck, Tractor, Race Car, Hotrod, whatever.
Steve@B&B
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 7:30am
I like to use di-electric grease that is used with aluminum wire when making joints, terminating.
