barrel type sprayer
wordman077 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wordman077 Quote  Post ReplyReply Direct Link To This Post Topic: barrel type sprayer
    Posted: 14 Feb 2011 at 7:45am
Anyone have any pros or cons on a vertical barrel type sprayer vs. a horizontal one?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 7:50am
I guess my only concern would be the withdrawl location. If it is in the bottom there is no problem. If it is in the top you could encounter problems getting the pump primed. It looks like the pump they are using is a small roller pump. Be sure that there is a screen ahead of the pump, roller pumps are not very tolerant of FM in the spray material.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:17am
dad used one for years, had 2 mounted on the back of a vac case, and yes...it was a pain to keep them primed! the slosh was smaller tho!
