Barrel stove |
Page <12 |
Walker
Posted: 21 Dec 2025 at 5:08pm |
Back in the 70s my neighbor sent away for a book with plans to build what they called either a HASHA or a hasha house. As I recall, it was a small block square more or less an outhouse looking thing out of cement block as big square or rect. as you want to cut logs. Partially filled with sand while you added sand, you buried aluminum rods in it. I remember we were laughing about something at the time, and it seems to me it was because they left out transferring the heat to your house and a roof parts. That what I thought I was giving u when I said to google it up. Suppose to be all the rage in Switzerland or somewhere at the time. I never heard of it again till now.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9689 |
Posted: 22 Dec 2025 at 4:29am |
I have another question.
I found a long section of stainless triple wall stove pipe with a roof boot and a cap. It’s in very nice used condition. The barrel stove kit uses 6” pipe. Can I run the 6” up to the 8” without draft problems? Would be somewhere around 4’ of 6” pipe then an adapter. |
jvin248
Posted: 22 Dec 2025 at 8:24am |
Before cutting into your roof, can you set up the pipes you want to use with the stove outside and actually test it? Use guy wires to hold the top of the pipe. We used a wood stove in the house growing up and it was 6in round up and six ft to the wall and then the vertical rectangular block+brick chimney with larger cross section. So seems like you will be ok, but a test can prove it will work. . |
Walker
Posted: Yesterday at 4:35am |
It's ok to go smaller into larger on the chimney side, but I would do it close to the stove outlet and get the bennies of larger for more distance. If it starts burning hotter than you'd like, slow it with the draft. I really doubt if it will, but what do I know. First sentence is confusing, what I'm saying is keep it big from back of stove to top of chimney after it exits the stove.
Edited by Walker - Yesterday at 4:41am |
Page <12 |
