Barn Fresh B...
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: Barn Fresh B...
    Posted: 06 Sep 2010 at 4:01pm
Circa early 40's
are genuine." - Mark Twain
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 4:06pm
what is sticking out behind that thing about hitch high??
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 4:33pm
the cultivator frame is mounted but looks like shovel shanks are all removed and the lift handle.   Not sure why you would do that, I don't think the drawbar is very usable when that is in place.
I do it to get my B on the trailer for shows, and when I am ready to pull it off.  Maybe they found it is easier to remove the frame from the tractor and store it with the shanks removed, and they were in the process of removing or re-installing the cultivator when the picture was taken.
Edited by Rick of HopeIN - 06 Sep 2010 at 4:40pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 5:12pm
And all that nice mowed hay , and the rope for the hay forks there on right. Ah yes the loose hay and putting it up, remember that well . And then the NH bailer with the Wisc engine behind the CA. WC was used to move bale wagons from field to the barn
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 5:35pm
That mow would only be a third full if they would have baled it first. LOL I'd like to find a barn fresh B in that condition.
clovis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clovis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 6:59pm
Wow...look at that loose hay.
We've grown so accustomed to baled hay in our society that people would think you were crazy if you put up hay like that these days.
Edited by clovis - 06 Sep 2010 at 7:00pm
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 7:23pm
Also noted the scaffolding over the "barn floor" . I remember laying boards on the stringers and piling the sheaves of grain up there to maximize the holding capacity of the barn prior to threshing later on in the fall when the threshing crew came around. The work involved in moving those sheaves from the scaffold to the feeder housing was a real exercise in logistics involving various "Pitchers" but it worked!
It is sometimes hard to explain how we did things back then but it was labour intensive in any event.
Ken McGregor
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 8:13pm
I still put up loose hay, and my neighbors to think I am crazy.  Although I don't do that much.  Tucker, you would be surprised how much loose hay will pack.
Sorry it isn't black and white but here is the CA with loose hay.
Edited by firebrick43 - 07 Sep 2010 at 11:36am
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 8:23pm
   I rember those days onley my tractor was brown and had duel horzontal tail pipes
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 9:19pm
I have a tractor or two like that as well.  They take in grass and air and give you Gas back!
Edited by firebrick43 - 07 Sep 2010 at 11:44am
This page was generated in 0.112 seconds.
