Barbless Hose Barbs ? |
| Author | ||
BuckSkin
Joined: 12 Sep 2019 Location: Poor Farm Points: 1178 |
Topic: Barbless Hose Barbs ?Posted: 20 Jun 2024 at 4:18am |
Yes; those be the animals I was looking for; thanks.
| Sponsored Links | ||
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Thanks(1)
Posted: 18 Jun 2024 at 10:51am |
Hydraulic Coupling - Single Bead - 6SB-6RMP90 ...Use w/ Low Pressure Hose Such as Multi-Purpose or General Purpose Hose. Single Bead Fittings Are Quick Connecting, Field Attachable & Reusable. Barbed fittings are a simple Slip-in style fitting that works with many different types of Tubing and Hose. Some barbed fittings may only have a single bead ... Place your order online for Gates Male Pipe with Cone Seat (Single Bead) G37100-0806 and pick it up at your local abcauto for free. |
BuckSkin
Posted: 18 Jun 2024 at 10:47am |
YES ! THANKS ! I could not think of anything they might be called that a search would understand. I have my share of the ordinary barbed kind here and there when they were all I had; but, I much prefer the smooth kind. I have never had one even offer to leak; and, if I ever have reason to pull a hose off, the hose comes off undamaged and ready to clamp again. As for taking hoses off, after I found out about JIC adapters and swivels, I only ever use them in places where a hose might ever need be removed for whatever reason. But, on a run of hose where the hose needs make a turn and might tend to want to kink, I like to use a 90° barb of whatever else is warranted. I have never found such; but, I wish they offered short lengths of bendable tubing with hose barbs on both ends just for such purposes. Thanks for heading me in the right direction.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Thanks(1)
Posted: 18 Jun 2024 at 6:26am |
they are called “beaded” or “single bead” fittings
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Thanks(1)
Posted: 18 Jun 2024 at 5:21am |
Hose nipples have just one barb on the end and are more removable
BuckSkin
Posted: 18 Jun 2024 at 3:18am |
I have searched and searched and must not be calling them by their proper name.
For fuel lines, I very much prefer those smooth-shanked hose "Barbs" over the more common barbed hose barbs. Yet, when I try to search for them, I keep getting references to barbed hose barbs. I know such an animal exists as I have used them for years. I need a few 3/8" 90° elbows. I prefer to employ a 90° barb in places where otherwise the hose would want to kink. What do I call these barbless hose barbs ?
