Bandsaw mill guys on here? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10769 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Aug 2025 at 5:26pm |
Any of you guys have a portable bandsaw mill on here? Looking for advise on a building for one. Thanks, Tracy
acjwb ![]() Silver Level ![]() Joined: 28 Oct 2009 Location: WV Points: 307 |
If you use Facebook, search for Woodland Mills. The group has several posted.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
I was gonna build one, then I came upon opportunity to acquire one from the estate of a close friend. It's a Woodmizer LT40, towable fully-hydraulic loading, log turning, clamping. Glad I didn't build one, this towable got me operational and making lumber much faster than if I'd built my own. I now see all the mistakes I WOULD have made...
![]() Edited by DaveKamp - 29 Aug 2025 at 7:45pm |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24666 |
Make the building 10 feet longer and wider , taller too ! NOISE will be a huge issue as it bounces off the walls. Lighting will also be a challenge. Consider room needed to clean up the floor. Mine was outside so easy for the A-C forklift to lace logs onto the sawmill. Really miss the mill..it was fun to operate even though it never paid for itself.....
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1285 |
You need either a building huge enough to get all the way around the sawmill with a front end loader to handle logs, lumber, slabs and sawdust, or a tiny shed just big enough to park it out of the weather. Any compromise will result in frustration, so think carefully about which item you are most willing to deal with the frustration. We currently are running a Woodmizer set up in an open field with ample room all around. This allows a truck to sit behind the mill to pile slabs and edgings on, and we have a flatbed trailer sitting on the end to pull the good boards onto. This leaves the infeed side open for loading logs. We do have three of us keeping things moving so it works out quite well. A tiny shed with an opening just large enough to feed logs in and remove lumber out through the same opening can be used, it just slows things down and requires extra fiddling around. |
Either that, or the building needs to have an overhead gantry with log clamp, and a floor with conveyor or auger. The sawdust is generally easy, and my Kubota BX1800 makes quick work of cleanup, helps push logs onto the lift, and carry cut pieces off to dry, but Lots of bark accumulates around mine. Mine DOE have the carbide-tooth debarking motor, which I didn't know anything about when I got the mill, and I didn't think it'd be very necessary, but after the first few, I realized how much it helped the blade stay sharp... Hydraulic loading and turning are a MUST!!
