Bad starter button on B-112?
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Topic: Bad starter button on B-112?
    Posted: 04 Feb 2016 at 10:19am
May go look at a B-112 this weekend that owner says has a bad starter button - sometimes makes contact and spins to start - sometimes not.  Owner claims power is coming thru ignition switch to button.
Is there an easy way to jumper around this just to get tractor running to be able to see what kind of condition the rest of the tractor is in while running?
Thanks.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 9:17pm
take a #10 or so wire and go from battery to terminal on starter - or just same wire and jump across solenoid terminals with the key in run position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 7:03am
Coke's right again ! Just be careful of the sparks when you connect.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 3:14pm
Thanks, guys.
Yep, I had asked all the right questions to the "owner" and had received satisfactory answers, so took off this a.m. very early for a 2 1/2 hr drive one way to go to look at the tractor, with the intention of purchase if everything was the same as I was told over the phone and messaging.
Found a couple of other things wrong, changed my offer price which he accepted. Went to jumper the unit, and all it did was spark on the battery - no turn of the starter/gen.  Turned on the lights, the jumpered to see if current was going thru my wire to starter, lights dimmed considerably, so we knew that power was going to the starter.  Discussed further on when this happened.  Owner said last fall, and when he asked "dealer" he bought the unit from, was told it was only the starter button......Un huh.  Found out that originally the motor did turn over correctly, didn't start, but owner didn't w ant to continue to run starter for fear of "burning" out the starter.  Maybe what happened - who knows.
At this time I changed my offer again to something I felt I could live with and still get a working tractor.  The owner declined, said he guessed he paid too much for the tractor when he bought it approx. year + ago.  He told me what he paid, and I agreed that he paid too much.
So - still on the lookout for one of these B-110 or B112.
Thanks for allowing my long winded explanation!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:42pm
Hang tight Merle. They're out there. You'll get one!
Rocket 88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rocket 88 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 9:54pm
Macvette seen one for sale in Portville NY its a HB212 with mower deck, blade and tiller but its a long drive for you. I have bought a lot of good tractor parts in this town.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 11:34pm
Thanks, Rocket.  Yes, I have seen a few for sale, but all seem so far away.  Darn!
This page was generated in 0.234 seconds.
