Bad gas
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: Bad gas
    Posted: 02 May 2020 at 10:02pm
Got's some from the local independent owned station last week. Was making delieverys, stopped and filled up, had less than 1/4 tank. I left town and immediately noticed the mpg gauge went from 23.6 mpg down to 17.3 mpg. Thought I might have a flat tire. Stopped and walked around the pickup. When I got behind it, the exhaust stunk so bad I had to walk away from the rear of the truck. The guys get their gas straight from the pipe line. I wonder what they had been pumping thru the line before the load of gas? Apparently didn't get it cleaned out. Truck was running back up to 23.4 on convience store gas today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 12:32am
we've had that happen here too, always from independent fuel stations. they seem to want to blend chit in the gas to make another buck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 5:52am
The 'contractor' filled up his Dodge diesel PU with 'cheaper' fuel, maybe 20c/gallon. Well his truck limped home, had it towed to service, $1000+ later, tank,filter and lines,etc. were cleaned out.
Yup he got a DEAL on cheap fuel !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 7:39am
Tank farms are FULL to the rim right now, they are having to deal with longevity of gas they have not for some time. Current 'Reformulated' or even the newly developed sour crude oil forced refining has a Short life in storage as we have all seen where that does equate back to the stored fuel at the refineries. To make it usable in the short term they blend Old distillates with fresh to 'extend' the life cycle while that is at a cost. Cannot add more additives or stabilizing agents to hold it as the current refining process produces a unstable compound that seeks to reclaim a stable less desirable form.
The only other aspect they can do is sell all they currently have, produce MUCH less, store unrefined crude oil wherever they can to use that as little as possible to keep stored refined products levels limited. And yes, that has begun.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 10:41am
I thought this was going to be about the burritos at the gas station, not the gas itself...
weiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 1:53pm
Bad gas from them too,  especially at the rear,,
Real heros wear dogtags, not capes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 10:12pm
i thought they was talking about me! whew!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 2:52pm
They WAS!!  You was in the back of his truck at the time,,,,,,,,,,,wasn't you?  Sneakin over there to get some of that honey he's gots.  An maybe stealin goats too?  Or maybe you WAS at home, but with a strong Westerly wind,,,,,,,,,like we been havin,,,,,,,he might a just smelt you too.....
