back to my one ton,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: back to my one ton,,,,
    Posted: 23 Mar 2026 at 10:30am
 If I remember correctly,,,I have a 1989 GMC one ton trk with a 454 Automatic and the dreaded TBI. I would like to change the TBI to a 4 barrel carburator and remove all the extra BS that has to be almost perfect for the frigging TBI to run correctly.
 I'm positive that with so many DIY's on this site ,,,that many have already done this conversion successfully,,,!!!
 I don't have a manifold yet but do have several Holly carbs from 650 to 1200 CFM.
 Anyone wanna share some knowledge,,,??? Many Thanks in advanceClapClap
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 10:48am
you will need to change the fuel pump so you dont over presure all of it and have a  fire
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 1:13pm
 Hey Thanks HudCo,,, Chit,,,and I had just installed a new in tank unit,,,,,,
   Whoops,,lookin like more work,,,mayhaps an in-line pressure regulator set at ,,,??
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 3:20pm
Regulator was my thinking, around 5PSI
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 3:41pm
Maybe find a 'donor' truck with 454/carb setup ??
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2026 at 9:07pm
Ive got a 88 3500 gmc i did all that too. Got a edelbrick aluminun intake and fuel pressure regulator from jegs. Got a stage 2 quadrajet from national carbureator. Put a hei ditributor in it. Its geared 4.56 so i put a 4l80e in it. Now its trouble free and is sweet as sugar
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2026 at 9:09pm
PS. People want to buy it all the time but it not for sale at any price
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:18pm
 Hey 8070nc,,,,sure am glad you chimed in,,,!!
 What year distributor did you use?? wiring hookups,,??
 I hope to buy an aluminum manifold off the Marketplace unless,,,,you gots one in your back pocket you want to sell me,,,,,
 I dont think this block is tapped for the mechanical fuel pump and since I had just i nstalled a new intank pump,,,I;ll just go with an inline regulator like yours.
  One of the guys says about 5 PSI....?
 Anything  else,,??  Many THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 2 minutes ago at 8:18pm
 I'm finding several aluminum intake manifolds of Ebay and about half of them list "Air Gap" ,,,,,,?
I;m just looking for smooth running and best gas milage and mostly to get away from the very troublesome TBI system,,,,,Anyone,,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 13 minutes ago at 9:07am
If it was my truck id stay away from market place or ebay. Id go to jegs or summit racing sites and get a name brand intake such as a edelbrock rpm airgap. On a airgap manifold the intake plenum is seperated from the part that covers the lifter valley. In theory it gives a denser intake charge for better efficiency. It will be cold natured because the carb doesnt warm up as fast. You can get intakes that are not air gap. The reason i say reputable maifold new not used is if the intake is warped or something and you have a intake leak you will have problems that are hard to diagnose. As frar as distributor id get a accel hei   It will do fine out if the box a all you have to do to hook it up is get switched power ot it
1984 80780
1957 D14
616 tractor
