back to my one ton,,,, |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13766 |
Topic: back to my one ton,,,,Posted: 12 hours 51 minutes ago at 10:30am |
If I remember correctly,,,I have a 1989 GMC one ton trk with a 454 Automatic and the dreaded TBI. I would like to change the TBI to a 4 barrel carburator and remove all the extra BS that has to be almost perfect for the frigging TBI to run correctly. I'm positive that with so many DIY's on this site ,,,that many have already done this conversion successfully,,,!!! I don't have a manifold yet but do have several Holly carbs from 650 to 1200 CFM. Anyone wanna share some knowledge,,,??? Many Thanks in advance
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4065 |
Posted: 12 hours 33 minutes ago at 10:48am |
you will need to change the fuel pump so you dont over presure all of it and have a fire
desertjoe
Posted: 10 hours 8 minutes ago at 1:13pm |
Hey Thanks HudCo,,, Chit,,,and I had just installed a new in tank unit,,,,,, Whoops,,lookin like more work,,,mayhaps an in-line pressure regulator set at ,,,?? |
plummerscarin
Posted: 8 hours 1 minutes ago at 3:20pm |
Regulator was my thinking, around 5PSI
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25197 |
Posted: 7 hours 40 minutes ago at 3:41pm |
Maybe find a 'donor' truck with 454/carb setup ??
