B212 rear light not working |
NATHAN CAIRNS
Joined: 07 Feb 2016 Location: Brighton IL Points: 104 |
Topic: B212 rear light not workingPosted: 14 Apr 2017 at 2:02pm |
The rear light on my b212 isnt working. I checked the voltage and there is none. What could have went wrong
B212, WD45, B, 912 Hydro
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11163 |
Posted: 14 Apr 2017 at 2:57pm |
broken wire
GlenPettit
Joined: 16 Feb 2016 Location: SC – Michigan Points: 26 |
Posted: 14 Apr 2017 at 7:23pm |
Also check your contacts, where the wire connections are attached. It's common for those flat surfaces to oxidize, like 'rust', and build up a thick non-conducting surface, kinda like a washer, preventing the electricity to get through . . . a very simple fix; just sand those contacting surfaces and coat them with Vasoline or a conducting gel. This is probably a more common cause than a broken wire on our tractors.
Good Luck
Glen
NATHAN CAIRNS
Posted: 17 Apr 2017 at 4:41pm |
ok thanks i took a dremnel and sanded the posts but it still dont work ill pop the sheet metal off and take a look at the wire and other posts tomorrow
