B212 backfire
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Topic: B212 backfire
    Posted: 12 Jun 2016 at 1:12pm
I was running my b212 today and it was 100 degrees and I was trying to run some gas out of it since I don't run it much. I ran it almost wide open and about ten minutes later I idled it and it started backfiring every five seconds or so. It didn't do that when I started it
B212, WD45, B, 912 Hydro
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 4:46pm
probley some water in the bowl
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 5:54pm
It has always been in the garage though and what is the bowl. Is that the carb
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 5:44am
There is (or should be) a sediment bowl under the fuel tank.  You'd need to remove the left side panel to see it.  May have gotten enough condensation in the bowl that it got some down to the carb.  Easy enough to remove and dump out.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 10:05pm
float bowl on the carb just needs one drop of water to foul the main jet dosnt take much to get condensate
This page was generated in 0.176 seconds.
