B210 Air Filter |
minerfarmer
Joined: 20 Sep 2009 Location: central Ill Points: 5 |
Topic: B210 Air FilterPosted: 15 Feb 2017 at 7:28pm |
I have a B210 with a Briggs 243431 engine that has been setting about 6 years. Took the air cleaner apart and the foam element had turned to mush. Any body know where to get a paper element with a foam precleaner for this engine.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 16 Feb 2017 at 4:48am |
Original filter is all foam, saturated with oil. Gary |
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 21 Feb 2017 at 7:02pm |
The later Cast-Iron Briggs had paper filters. You can use a paper filter with the foam pre-filter but will need to change out your air cleaner mounting stud in the carburetor as you need the longer one.
