B125 cam bearing removal tool
JIminArkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JIminArkansas Quote  Post ReplyReply Direct Link To This Post Topic: B125 cam bearing removal tool
    Posted: 16 Mar 2011 at 7:37am
I discovered in my junk pile. Went searching for a way to remove cam bearings without buying a driver kit. Picked up a 42" craftsman mower deck mandrel shaft out of the junk pile and discovered the end where the blade attaches is the exact size of the OD of bearing. Took 5 minutes to remove the three bearings. Just add the original nut to threaded end and place a 7/8 socket and extension and the center bearing is easily reached. Just wanted to share this idea with others who may be tool challenged like I am most of the time.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 8:56am
How well I remember those days,,,tool challanged. 20 years ago I found a way to purchase my first lathe and an old milling machine and today I realy dont think I could enjoy working on old stuff without them. Not meaning to brag but your post reminded me to be thankful.  When you install the cam bearings you need to be very careful about alignment as they can easily be started and driven in crooked. Once started crooked they often will not  self align in the bores. That's why the drivers have a cone shaped guide for the extansion  and you allways drive the end bearings from the far end of the block.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 6:28pm
I had to put new cam bearings in my RC several years ago but lacked a "tool". I had an old baseball bat in the barn and cut out a section with the larger diam same as the OD of the bearing. Used it as a driver against the bearings. I know, it's hokey but it worked.
Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
This page was generated in 0.151 seconds.
