B12 tractor pulling |
Larry W.
Topic: B12 tractor pullingPosted: 31 Mar 2016 at 8:48am |
Has anyone here pulled a B12 with any success? My kids have one they would like to try and I was wondering if anyone had any advice on them. They would just be pulling it in a stock class for now, thanks
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 31 Mar 2016 at 11:11am |
Slipping of the belt drive was my problem, just added a spring with a little more tension. might also want to look for a set of turf tires off an older Sears tractor
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 31 Mar 2016 at 7:25pm |
I think the weak point becomes the axle tubes. Have talked to one guy who kept destroying his differential as well. Both can be dealt with. The SimpletrACtors.com forum has some guys that pull.
AaronSEIA |
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Posted: 04 Apr 2016 at 11:39am |
They work ok for the stock class. You can do stuff to the diff as said. You can change rear pulleys easy if you want to change gear ratios too.
