B12 pulling tractor differential question...
Kcenderjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcenderjim Quote  Post ReplyReply Direct Link To This Post Topic: B12 pulling tractor differential question...
    Posted: 07 Jul 2017 at 10:52pm
I have been told 2 ways to make the differential into a positractiin. 1st way is to put all the gears so that they are locked into the gear on the rt wheel hub, 2nd is to switch them from HL-HL-HL-HL and make them LL-HH-LL-HH . I'm not getting into welding the gears so that's out of the question. Has anyone done either one of these and which one works?
Thank you in advance.... Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 7:50am
Tighten down the setscrews tight and it is locked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcenderjim Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 11:53am
I have tried that and it don't work as well as I need it to that way. That's why I'm trying to lock up the diff instead.
