B112 questions |
Ewhitford
Topic: B112 questionsPosted: 09 Mar 2020 at 12:06pm |
I have a b112 with a 16hpBriggs in it with a 1inch shaft for the crank. What size in diameter should be used to power front attachments ? 2nd question, I have no power to pull my garden trailer espesially going up hill. I tried several belts, Watched the drive system and nothing seems to be slipping so what am I missing. I have this issue whenever going up a hill or towing our sprayer, wagon or spreader.
Thank you.
Mikez
Posted: 09 Mar 2020 at 8:29pm |
Is it a variable speed
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11383 |
Posted: 10 Mar 2020 at 2:53pm |
Check the pulley on the rear, mine throughs the out every so often, can't keep set screw tight.
Edited by tadams(OH) - 10 Mar 2020 at 2:54pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 16 Mar 2020 at 9:31am |
you cant beat that modal 32 briggs for power, shaft is 1 inch for the snow blower if the 16 has low power make sure somone has not put a flywheel on with the wrong ploarity i have seen done and it still runs but very poorly
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 21 Mar 2020 at 9:49pm |
Have you gone through the adjustments for the variable speed system in the service manual? These need to be adjusted periodically as the belt and linkages wear.
Animal Cracker
Posted: 23 Mar 2020 at 4:21pm |
You know its suppose to be a 12 hp right.
Orangeisgreat190
Posted: 09 Apr 2020 at 10:31am |
I have a B112 with variable speed. Try taking you heel and pulling back toward you on clutch pedal. See if this helps. If it does, I would say ACmowerguy is right, check all rearend adjustments in manual. Also, I replaced the belt on mine and it helped tremendously. The pulleys move in and out to change diameter for speed change. This really wears on the side of the belt.
Orangeisgreat190
Posted: 09 Apr 2020 at 10:32am |
Forgot to mention, check clutch return spring as well. It could be weak.
