B110 Allis Chalmers
Gary Benson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Benson Quote  Post ReplyReply Direct Link To This Post Topic: B110 Allis Chalmers
    Posted: 26 Jan 2025 at 7:48am
Long time listener, first time caller
Where can I find the nylon pins that tighten down against the axle to increase traction? And the set screw/bolts that tighten it down? I twisted one off. Maybe a hub replacement is in order?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 8:41am
Hi Gary
Welcome to the Allis Forum (from another Gary)
I have an Allis B-110 Parts Catalog.
Are you referring to what is identified as the R/H Wheel Hub Assembly:
There was a change at B-110 Serial 68017
   2025670 Bolt Traction Control, 2025495 Plug - Hub
Effective at Serial 68017 the Bolt changed to:
   925261 Setscrew, skt. hd., cup point, 7/16 NF X 1/2
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Benson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 8:57am
Thanks Gary. I just got this tractor a few months ago and I know very little abo ut it. Yes it is the Right hand hub assembly. I watched a Utube video and tightened the set screws down which helped some but not enough. I finally tightened them so much one twisted off. Maybe the nylon pieces were worn down. Is the axle supposed to be knealed so the nylon will grip? I'll look at the serial number and see where it stands. An improvement would be very welcome!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Benson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 9:30am
60797 is my serial number so it's definitely a dinosaur. Any ideas where a guy can find parts for this thing?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 5:40pm
There are a few possibilities for Parts.
The best would probably be 'Sandy Lake Implement' located in Sandy Lake, PA.
Many Forum Members speak highly of Brenda.
Be sure to mention you are a Member of The Allis Forum.
There is also an 'Allis Parts and Services' Section in the Forum.
Most of those contacts are members of the Forum.
G
https://www.sandylakeimp.com/search/inventory/availability/In%20Stock/usage/New
Another popular site that only deals specifically with Allis / Simplicity Lawn and Garden Tractors along with all their attachments.
It is called 'Simple TrACtors'   https://simpletractors.com/
You need to sign up, but it will be well worth it.
Edited by Gary - 26 Jan 2025 at 7:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 9:07pm
We might have the plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Benson Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 5:45am
Thanks. Will check them out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 1:13pm
We have the parts to
This page was generated in 0.199 seconds.
