B10 tune up
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: B10 tune up
    Posted: 10 Jul 2014 at 8:55pm
Where can I find a correct set of points and condenser for my big ten? I have a condenser that won't fit under the points cover, and it causes my points to rust. So where can I find a condenser that will fit under the cover?
1950 B, 1952 pulling wd, and 1954 wd45
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2014 at 9:31pm
Any small engine shop should be able to order the right ones either through Briggs or aftermarket. They can also be found online.
Breaker Points # 298185
Condenser # 298060
I would recommend using OEM Briggs points as the quality is much better.
This page was generated in 0.166 seconds.
