B1 Governor
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: B1 Governor
    Posted: 21 Aug 2014 at 8:57pm
My B1 seems to get very sluggish when good and warm after mowing for quite a while. The governor lever seems to stick and it is very slow to pick up speed or to drop revs when the throttle lever position is changed. When cold or only moderately warm it works fine. I've blown out all the shrouds and fins so I have good air flow for cooling. If I park it for 1/2 an hour or so, then it's OK for a while.  I'm not sure where to look next.
rdmanone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdmanone Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2014 at 5:54pm
I just bought a big Ten and the gov was sticking.  I had to take the engine apart to fix it.  A little 1500 gt sand paper so it slides like it should.  It's some work but I had to do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 9:36pm
Thanks, I kinda thought it might be an internal problem.  It'll wait 'til winter as it's got a lot of hours on it and is due for an overhaul anyhow.
