B won,t move
ihscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Topic: B won,t move
    Posted: 06 Jan 2017 at 12:50pm
Ok. I was out plowing with my 1940 B. Only 22 inches of snow and -4 degrees. I got stuck and almost got out. Anyway, The machine's rear wheels quit turning while in gear. The PTO still operates for the loader bucket. Any ideas of what to look at when I head back out into the tundra?
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 1:06pm
3 things come to mind. None of them easy.    Transmission not going in to gear, ring gear and pinion, or final drive gear or shaft.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 2:35pm
If the brakes work try stepping on one at a time if it's in a final drive you should be abel to limp to the shop by holding the broken side brake
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 8:16pm
I hate to say it but it looks like my favorite is not too good.
Thinking of what is said above - and they are right on - perhaps a loose nut on the wheel?
In any event wish you the very best of luck on this.  Let us know how it goes.
Good Luck!
Bill Long
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 8:40pm
Check for frozen water in trans.
Can't fix stupid
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 9:51pm
Carefully tow it back to the shop. Remove the PTO housing and pickup your spider gear cross pin out of the bottom. Hope nothing else is broken. Good luck
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 10:45pm
Or teeth ripped or worn off axle or hub or both.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 7:20am
If you were going from forward to reverse repeatedly the problem most likely will be just below your shifter stick.  I would guess it would be in the side plate assembly but could just be a worn fork that let the slide gear set free from the gear that would move the tractor.
Pictures of the side plate assembly with forks and picture of the grooves the slide forks have to be in.
In the picture the gears are in the neutral position which is my guess to your problem. If it is the case you would have to examine the side plate for the cause.
Edited by Dick L - 07 Jan 2017 at 7:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:00am
I vote for Dicks plan. I have seen the shift lever pop out and get stuck in 2 gears or neutral.. Does the shift lever  "FEEL" like it goes into all 4 gears ? .... Hard to believe you broke gear teeth in the finals.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:12am
Do what Dick said,
then if it's not the shifter assembly,
 it's probably what Dakota Dave said.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 12:45pm
STRIPED REAR WHEEL CENTER OR CLUTCH IS SHOT  [WILL TURN P T O SHAFT BUT SLIPS UNDER LOAD ]
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:25pm
I'll be checking it out tomorrow and will let ya know
