B with hand brakes?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: B with hand brakes?
    Posted: 11 Sep 2012 at 10:31pm
I'm looking at a B that my wifes uncle has, wf, hyd, woods mower, but it has hand brakes and i've never seen this before on a B. is this common?, factory?, aftermarket? i'll try to get pics and a serial number. i also has some type of bracket behind the seat and in front of the platform(foot rest). the front one has been adapted to take a cyl. for lifting the deck. i'm assuming that these are for hanging some type of mounted equip, cultivator maybe?
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:54pm
Early B and C tractors had hand brakes.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 12:17am
All my 38's and my 40B have or originally had hand brakes. My Grandfather's B has a mechanical lift for the mower and my 44C has hydraulics. The Bracket behind(?) the seat may be a rock shaft that was/is used to help keep the implement pushed toward the ground. the B's also had implements that could attach under the tractor (where the mower deck is). Pictures are always appreciated :-)
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
jeffsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 7:01am
MY 38 B HAS HAND BRAKES,LOVE TO SEE YOUR B!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 7:12am
My 39 has hand brakes
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 9:16am
Allis started putting foot brakes on the B's in 1941 I belive along with the C's, The C's only had foot brakes for 1 year, 1940 was the first year that lights and starter were availible on the deluxe B, as they called it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 9:18am
the C only had hand brakes for 1 year, sorry.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 9:46am
My 1941 B had hand brakes.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Jamest1982 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamest1982 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 3:40pm
Does anyone know what the threads are on the hand break levers. I am trying to clean the up and want to run a die over them but can't find the correct size. The small locking levers are 1/2 13.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 10:32pm
lever ends are 5/8 inch - 18 thds per inch... National Fine Thread.
if you have a dial caliper it should read .625 inch OD
Edited by steve(ill) - 05 Jun 2024 at 10:36pm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 11:04am
I would guess the brackets behind the seat are the lift arms for plows and the "bracket" under the foot rests is the drawbar for attachiing the plows.
It would have been nice if a set of two-way plows had come with the tractor.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 6:53am
my ‘39 B has hand brakes
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 7:21am
You do realize that the 1st half of this thread is 12 years old!
