B WFE on a CA
Kforeal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kforeal Quote  Post ReplyReply Direct Link To This Post Topic: B WFE on a CA
    Posted: 02 Mar 2012 at 5:51pm
Will a B WFE fit my CA.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:22pm
Yes but it takes a little rigging.
cadcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadcorey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:32pm
It will go on and yes it takes a little work. I am putting one on a C and the biggest thing is the steering arm out of the box. You need to have the one from a B. That is because the C arm has a tie rod end and the B has a steel ball end. You also need the right radiator support. As long as you have all the parts for the front end it should be no problem.
