b vs c |
Author | |||||
ewbs79 ![]() Silver Level ![]() ![]() Joined: 17 Mar 2011 Location: trenton,mo Points: 81 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Mar 2012 at 7:17pm |
Ok I have my b going and I also have a c that is next to get running I know the c is a touch bigger but does it have more hp? Not really sure the differences between the b and c is basically what I would like to know if some people care to help a dummy out
Sponsored Links | |||||
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
B and C have pretty much the same motor and HP if not identical.
SteveC(NS) ![]() Orange Level ![]() Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
Yup, identical.
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6486 |
Same motor. Different gear ratio and maybe a little more weight on the C will make a slight difference. Both are handy little tractors.
I know the c is wider. Is 1sta gear. Slower
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Final drives are the only major difference as the C is geared a bit different.Engine, sheet metal and transmission are the same
Charlie
Protrucker ![]() Orange Level ![]() ![]() Joined: 25 Apr 2011 Location: Broome Cnty,NY Points: 718 |
According to Tractor Data, The C has more horsepower.
B
C
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Except the radiator shroud. The B was a one row tractor and the C was a 2 row tractor, speaking of cultivating anyway. All B's had a wide front end, C's could be single,narrow, or wide front. I think you might find most C's had foot brakes and electric start because they came out later than the B. Early B's had no starter and hand brakes. The back wheels of a C had a wider stance than a B because of different length of the final drive. The drawbar on a C is a wider arch than a B to fit the wider final drives. OK what else? |
The B test was done in 1938 with a BE engine. When the C came out, the B had a CE engine just like the C. There was also gas engine at 5.75:1 comp ratio and a distillate at 4.75:1 so there would be another difference in HP. ![]() Edited by CTuckerNWIL - 01 Mar 2012 at 8:29pm |
I was comparing the B to the C with the gasoline engine. I don't know the difference between the BE & CE engines, but the data listed the same bore, stroke & compression ratios for the B & the C with gasoline engine.
Terry Dean's book says 23.30 on PTO for the C and 22.25 for the B on PTO. That is with the CE motor (1943-1957).
Well the 12.97 HP was from a test in 1938 (BE 116 cuin)before the CE (125cuin) engine came out. The C test was in 1940 with a CE gas (18.4hp)engine. I guess some details get lost in too much information. The same CE on distillate had less power(15.sompin). I don't know if there were different comp ratios for the BE engine. Too many numbers to look through
O
So essentially the b will not perform as well under the same load as the c with all the same motor because of slightly different gearing with the exact same ground speed? How does that work? I also put taller tires off of my c onto my b is this gonna hurt my ability to pull |
I can't tell you about the gearing, but the taller tires will make you go faster than the stock size for your B.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2243 |
I would love to have power numbers for the BE gas engine. You're right; I'm sure it's higher than the 12.97 drawbar horsepower that the distillate version was tested at. I always figured the higher compression gas motor was around 15 hp or so but I don't have anything to back that up. Just a guess. It should at least be between 12.97 and 18.4!
So let's say theoretically if I would put my shorter tires on my c it would slow me down but possibly give me more ability in pull with same pto speed? Does this sound feasible?
if I remember right the ground speed on the C is 1/2 mph slower than a B (at least in first)
Correct, the fenders are different. Makes sense that the shroud is different with the narrow front. How about the steering box?
Charlie
Foolster ![]() Bronze Level ![]() Joined: 19 Feb 2012 Location: Oak Ridge, TN Points: 9 |
I have a B I am rebuilding. Once that is through then I have a C rear end that I am going to put a four speed truck transmission and a Yanmar three cylinder diesel ahead of. From everything I have read the B and C were same tractor except for the early Bs with the smaller engine. The CA was really different with a four speed transmission. However, I think all the major castings have the same bolt patterns so you are able to make a working tractor from parts of any of the three models.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
After 70 some years you will not find much difference between the (average) BE and CE engines. You have to pull the head and use a ruller to tell the difference.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Below is a link to a good article on the B/C/CA tractors
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
It might have changed things some if the Snap Couple hitch had come out in 1950 as stated, but it didn't come out till 1953. Pretty good article though.
Edited by CTuckerNWIL - 03 Mar 2012 at 1:44pm |
