B steering
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Topic: B steering
    Posted: 06 Mar 2010 at 4:32pm
There is a long rod that goes from the steering arm up to the steering knuckle. In the end of the rod is a slotted plug and a cotter key in the slot. I'm assuming it's threaded. Is there a special tool to ge that out or a trick to it?
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 4:56pm
Manual(hammer) impact screw driver, make sure nothing is left of the cotter pin or nail. Could spray or soak it first.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 5:19pm
Yes it's threaded. I have a broken wood chisel that just fits in it and I put a cresent wrench on the chisel and turn it. Springs and cups inside so don't lose them. I did have to use heat on one once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:30pm
A drag link socket is what I use. It is basically an oversized screwdriver tip on one end, the other end fits on a 1/2" drive pull handle or ratchet. If it doesn't move easily use plenty of PB Blaster and heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:39pm
I do basically the same as Thad does. Crescent wrench and a chisel. After I get the drag link apart, I clean the threads with a small wire wheel on the end of my cordless drill. Does a nice job cleaning all the rust outta' the threads. A little dab on Anti-seize and we're good to go!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 8:15am
Thanks guys. I found a piece of flat bar that did the trick. Along with the Kroil and the flame.
