B steering gearbox-Ross vs Gemmer? |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8461 |
Topic: B steering gearbox-Ross vs Gemmer?Posted: 29 Dec 2025 at 1:19pm |
Which gearbox is preferred? My B has a Ross and it turns hard. Jack the front end up and you can turn the wheel with one finger, so I know it’s not in the king pins. I drove a different B and it was night and day different, so easy to steer. I didn’t pay attention to what box it had. Does one brand tend to steer easier than the other?
Thanks |
Joined: 11 Sep 2009 Location: illinois Points: 89348 |
Posted: 29 Dec 2025 at 1:28pm |
i think the Gemer has 3 teeth inside compared to the Ross that has One tooth or "pin"...I have several tractors and everyone has the Ross.. I think it was way more common and probably cheaper...
Nothing wrong with the ROSS if it is built up right. Normally the pin wears and you get excessive slop.. you can turn the steering wheel 30 degrees and no movement of the tires.. the PIN is worn out... I have never had one DRAG as you said.. Normally that is in the king pins / bushings / drag link area...
Edited by steve(ill) - 29 Dec 2025 at 1:33pm |
Posted: 29 Dec 2025 at 1:29pm |
here are Dicks pictures of the ROSS...
and the GEMER https://public.fotki.com/DickL/allis_chalmers_engi/allis-chalmers-c-ge/ Edited by steve(ill) - 29 Dec 2025 at 1:30pm |
Posted: 29 Dec 2025 at 1:31pm |
wjohn
Posted: 29 Dec 2025 at 5:15pm |
Not speaking from specific experience with those gearboxes, so take this with a grain of salt, but you could have something worn anywhere in the steering linkage, or even the king pins, and when you have the weight of the tractor on it and then try to steer with the extra force it requires (vs. up in the air with no weight on the front wheels), it puts something slightly in a bind. Could be in the gearbox or anything else, perhaps?
Edited by wjohn - 29 Dec 2025 at 5:16pm |
Posted: Yesterday at 8:23am |
I would be looking at the bottom of the king pin / bushing area... Some binding when you put the weight on it .... not much to go wrong with the arms, and the gear box is normally SLOP, not binding under load.
