B Starter
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: B Starter
    Posted: 15 May 2011 at 12:26am
I have a model B A-C tractor.  The starter switch is located on the bottom of the starter.  I recently had it serviced and the switch is now on top and I can no longer start it from the seat.  How can I get the switch back to the bottom of the starter"  Any directions would be appreciated.  Thanks.
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 4:50am
 You SHOULD be able to undo the 2 long thru bolts in the carcass and rotate the nose cone thru 180 degrees  to allow the solenoid to relocate on the opposite side. you will have to braw the carcass bolts out about an inch to do this, whille making sure the brush end cap does not move, then tap the nose cone off maybe 1/4 of an inch to dislocate it from the dowel peg, then rotate 180 dgress before tapping back on. This is assuming that you got your own, rebuilt starter back and it has 2 locating holes for the peg, and that you did not get an exchange unit that is pegged for the top mount solenoid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 11:27am
This is very helpful.  I'll try this.  Thanks Dave!
