B Starter Grounding Problem |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Mar 2018 at 6:48pm |
Ok...I know this has been covered before, but never thought it would happen to me. Since July 2016 the starter on my B has been very sluggish and most of the time doesn't turn the motor over. To "get by" I've been cranking it by hand. No problem. Always starts quick, and I have never had a kick back, until recently. I noticed it just didn't seem to idle right. It sounded like it was running "lean" and could die any second (I think you guys know what that sounds like). However, it would run that way all day long, but still didn't sound right. So, while it was running, I advanced the timing a bit and made it sound worlds better. Now it has that deep throaty sound and pulls much better than it did. (not that a B can rumble very deep, but you get the idea) The down fall of this is I can't hand crank it without a wicked kick back. I almost broke my arm the first time I tried, and now I'm a little hesitant to try again even several weeks later, as my arm is still sore. It's not how I'm holding the crank, the crank kicks back out of my hand, and makes the spin around and hits the back side of my forearm, all in an instant before I have a chance to withdraw my arm.
So, back story out of the way, I took the starter to the local shop to get rebuilt. They called me back and said nothing was wrong (opened it up, as well as tested it on the bench), maybe it just wasn't grounded well. I couldn't hardly believe that, as the tractor is inside all the time and has never given issue before. Nevertheless, they still charged $36 just to tell me nothing was wrong. I looked at the starter and everything looked clean. I brushed around inside the starter hole, and cleaned up the bolt that holds the starter in place. Tried starting it, and it busted right off. I shut it down and put all the tools away. Tried to start again, and it just clicked. I checked over everything again, and am now stumped. What do you guys recommend I do next? Thanks! Also...the dizzy was rebuilt by Steve recently, so I think everything is good there. Also using a known good 6V battery and heavy duty cables.
Edited by CrestonM - 26 Mar 2018 at 6:55pm |
Larry in NC ![]() Orange Level ![]() Joined: 09 Feb 2016 Location: NC Points: 1050 |
I bought a D10 with a 6 volt system that the previous owner had taken the starter to a shop for repair without getting any improvement in starting. He then bought a new battery and new cables, still no improvement. After I bought the tractor, I took the starter to another repair shop and when tested it worked, but the armature had some signs of shorting. Had the armature replaced and the starter worked fine. I assume that the starter is turning the engine but just too slowly to start it? If it is not turning at all, you probably have a bad connection somewhere.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88421 |
I guess you have the starter switch bolted to the starter with a push rod ?
only a few things it can be.. --contacts inside the switch --battery cable ends --battery itself --starter itself you said you have good cables... are the ends soldered on or pinched ? No corrosion INSIDE ?
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12016 |
Ten outta' ten starter motors that come in my shop for repair have bad arms in them. Simple as that. A lot of these so called "rebuilders" (and I use that term loosely") never check the armatures! I don't know what they do when they supposively tear em' down. The Armature is the heart of the unit along with the field coils. Yeah, you gotta' have the right size and good clean cables and all that jazz, but every one of these Starter motors that come through my door for repair because they're either sluggish, or click, or don't work at all, all need Arm's in them. On occasions, I'll come across one with a bad field coil also. For that, I usually put in a new pair, not to mess around with the old stuff. Are my rebuilds more expensive? YUP! Are they done right where they're gonna be in service for a loooong period of time? YUP! Even with that silly mechanical switch that's a big amp dropper when they're not making complete contact!
Steve@B&B |
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
I would think there are car starters from that era that would fit these tractors. Why would they specify a whole new starter when the wheel had already been invented? I'd wonder if there aren't car starters that don't have that silly mechanical switch.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
re:
Why would they specify a whole new starter.... Even IF you could find a 'same era' car starter, it'll need to be totally rebuilt. The nose piece ain't going to be the right, for starters(no pun..) I can see a pro taking 3-4 hrs to PROPERLY tear down, clean,refurb,install NEW bushings and brushes,bendix unit, TEST the arm and coils,lick of paint and load test it. Did I miss anything Steve ? Usually customers want the part now, not 1 or 2 weeks later, so an off the shelf rebuilt is the best case. A properly rebuilt starter will more than likely outlive you. I know using welding cables cured the hard starting issue with one of my tractors. ALso 6 volt batteries ain't made like they used to be. They require maintenance(check fluid every month of use) and be SURE the genny is 100%. |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
Creston you need to re check the timing as they shouldn't kick like you said. Steve is right on the starter I'm sure but I've seen em not crank if the timing is too far advanced. I think you have two problems.
John426 ![]() Silver Level ![]() Joined: 14 Aug 2012 Location: France Points: 310 |
How we can check if the armature is faulty?
Edited by John426 - 27 Mar 2018 at 7:00am |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
To help with the grounding problem, put some grease around the install bolt. That will help insure a good contact.
I am hoping you have lights on the tractor?! Start with your battery fully charged 24 hours BEFORE you try this.....it will give the battery a time to 'rest' for the next step. Turn the light switch to ON. Now, push the starter rod and see if the headlight go dim or go OUT. Dimming down is normal, going OUT is a BAD battery. You can bench test the starter yourself, just put it into a vise and hook the battery to the vise with jumper cables. Now clamp the starter into the vise so it can't jump around when you hit the switch with the other jumper cable. I have opened my vise and just sat the starter in it and held it down by hand. It is just going to push the starter bendix out and make it spin. Might scare you at first, but nothing to worry about. You have to 'lock' the starter switch in the 'closed' position, as if you are pushing the rod. Now, did it turn EVERY time you touched the starter switch? Are you using the battery out of the tractor? or a different one? ** (going up to the top and put a 1st step in) Now, after you get it running, get it timed. I think you've got it too far advanced. It shouldn't kick back at all....almost never.... Time it and then check the points gap... You need to buy a timing light and a dwell meter. Hope this helps!! Wish I was there to help you. |
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 710 |
I'm sure there were cars without "that silly mechanical switch", but every car that had the starter button on the floor had a similar mechanical switch. You don't want to send all the amps needed to spin a starter through a switch on the dash (or up by the tractor operator) so they put a switch down on the starter so that the electrical pathway was short. Sure, you can accomplish the same thing with a solenoid, but especially on a simple tractor, why? On my B, I took the switch apart and filed the contacts in it smooth so that there was a nice, big contact patch when I pull the rod. Simple to do. I don't want a solenoid. Added complication for no good reason.
1951 B
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
If the generator is the original 3 brush generator with the charging current set by the light switch it is dependent on the operator backing off on the charging rate after a while to keep from overcharging the battery. If the operator keeps it charging too long the water of the electrolyte will be dissociated into hydrogen and oxygen and the battery will need that water replaced often. The next generation voltage regulators were a definite step forward towards proper battery maintenance.
Gerald J. |
Thanks guys, I'll try some of these suggestions this weekend when I'm home. The shop does routine work on older automobile/tractor starters, and they said they indeed check out the armature. I've had work done by them before with good results, so I'm just not sure what's wrong. Guess I'll mess with it some more and see.
Ted, I do have a timing light (actually it was my great-uncle's. He got it while he was a mechanic in the army in the 50's. Works for 6, 12, and 24 V. Does great!) If I remember right, the timing hole is on the right side of the engine, where the implement mounts are? I have a belly sickle mower on mine, so the hole is covered. I'll just have to unbolt that mount and take a look. A dwell meter on the other hand....that's Greek to me!
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If it kicks back, your timing is too far advanced. If the crank hit you in the arm, your not doing it right. Stand to the right as you face the front, pull crank over the top and your arm can't be in the way of kick back.
For the starter, take the switch apart and file the copper contacts so they are FLAT and meet perfect when engaged. |
Dewll meter and timing light. Two "must have" items a mechanic needed when working on the old breaker point systems right up until they started using HEI systems. |
I stand as you suggest, and pull the crank up. When it kicks back, my arm doesn't get hit initially, but the crank makes a complete counter-clockwise revolution and gets me on the backside of my arm. Guess I need to get my arm out of the way quicker. Or most importantly...retard the timing a bit!
1951 B
You also need to check to see if the centrifugal advance mechanism is working. If its stuck in one position from not being lubricated properly or from the springs on the weights having broken, it won't retard the spark for crank starting or for battery starting. An engine with spark before top dead center can stall a good starter.
Gerald J. |
What makes these old Starters unique or should I say a PIA, is the pinch bolt type mounting. Most Trucks and Auto's of the day didn't have a pinch bolt mounting design, which puts the Tractor Starters in a different class with the nose cone type bolt mounts.
Steve@B&B |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5092 |
I never had one of these engines kick when timed at TDC before starting the engine. That is seeing the number one plug or plug wire spark. Not moving the crank at upon spark you want the TDC line in the center of the inspection hole. You can do it with your timing light. When timed in this manor I have always seen the fire line in the center of the inspection hole at high idle. Adjusting the timing on these engines different than with the Fire line in the inspection hole at high idle is miss guided and will reduce your performance.
If I could have gained performance with a different timing I assure you I would have been all over it. I built my own pulling track and tested every adjustment before loading tractors to pull. I have probly posted this video 50 times on here but even if you don't want to watch it, it gives me another reason to wish I was still pulling. https://www.youtube.com/watch?v=hM4YbM8keMM&t=51s ![]() ![]() |
Dean(IA) ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: NE Iowa Points: 430 |
Battery ground on a B or C tractor. I had this happen just once, but it
is possible. The little short battery ground strap goes to the pipe that holds up the steering shaft. That pipe is threaded into the torque tube and just one time, i found one that the pipe was not grounding to the torque tube. it is a really long shot but maybe worth considering. HTH |
I'll have to try that then. I will try to do it tomorrow, but I've got limited time and a million projects to work on. It's not fun being home only 2 days a week ![]() That is a very neat video! If that C is timed to TDC, I'll do the same. I know you are a B/C/CA expert, so I trust what you say.
Edited by CrestonM - 29 Mar 2018 at 6:01pm |
You always time the motor to TDC when it is rotated by hand or cranking... Once the motor STARTS, the centrifigual advance moves the timing to the FIRE mark..... Common mistake for beginners.
