B Sealed Pilot Bearing
00transamnh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Topic: B Sealed Pilot Bearing
    Posted: 02 Nov 2016 at 9:52am
I have just completed the engine rebuild on my 1940 B and am realizing that the shop that reworked my crank removed the oil wick. I think I would like to use a sealed pilot bearing and plug the crank hole. Does anyone have a pilot bearing part number to do this?
Is there a direct replacement that doesnt involve machining the flywheel?
Edited by 00transamnh - 02 Nov 2016 at 9:53am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 9:56am
just get a sealed version of the old bearing or simply measure width, id and od
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 10:28am
It's not going to happen! There is not enough room between the inside diameter and the outside diameter to put ball bearings in. The pilot bearing in your flywheel is actually a bushing.  The only way would be to have the flywheel bored for a sealed bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 10:34am
oops my mistake, i dont have a b.  was just assuming a bearing like wc with a  wick
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 11:59am
Ok thanks Dick. So that said, what pilot bearing have you folks been using for this conversion?
Edited by 00transamnh - 02 Nov 2016 at 7:02pm
scott in tenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 2:00pm
I bought oil impregnated bronze bushing. Drilled and tapped crank for plug. Has worked fine for me. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 4:09pm
I just greased the stock bushing and reused it....not uncommon for old tractors and trucks........ The oil impregnated bushing sounds like a good idea.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 4:21pm
This may sound dumb...I've heard of oil impregnated bushings before, but what are they? How do they work? Do you have to lube them?
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 4:27pm
did a clutch on like a 2002 chevy S10 pickup and they still used bushings in those. i was suprised by that. any way to save a buck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 6:13pm
Click on ----
Self-Lubricating Oil-Filled SAE 840 and 841 Bearing Bronze
Edited by Dick L - 02 Nov 2016 at 6:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 12:58pm
Anyone have a source for oil impregnated bushings? I am having a hard time finding them.
Looks like I need a 1-1/8 od x 7/8 id x 1 length
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 1:29pm
For future reference, it looks like McMaster Part Number 6391K273 is what is needed for an oil impregnated bushing.
