B Ross Steering Seal Question
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: B Ross Steering Seal Question
    Posted: 18 Nov 2009 at 8:14pm
I'm rebuilding a Ross steering gear from a 1940 B. The levershaft seal appeared to be almost like a packing ring. It looks like there were three different ones used on the B over the years. Is this currently replaced with a lip seal, or is there a different current seal that's used for this application?  TIA
are genuine." - Mark Twain
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 7:49am
Many years ago I replaced the levershaft seals using ones "matched up" by Napa (same OD/ID...but thinner). Emoryed the seal surface of the shaft and installed two of the thinner ones. Worked great for the several years I had the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 9:23pm
Greg, that's a good tip. I will do just that, thank you.
