B plow project.
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Topic: B plow project.
    Posted: 27 Aug 2017 at 7:26pm
Mounted most of the pieces today. Still more to paint including both plows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 7:39pm
Looking good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 4:28pm
Do you know that you have a rear lift shaft from a C not the one that is used on a B?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 4:44pm
Only Paul B and I would have  brought the C rock shaft to the builders attention. Get a B C mounted plow owners manual and see the difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 4:50pm
Edited by Ken in Texas - 28 Aug 2017 at 4:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 5:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 5:59pm
Note the use of C wheel centers as B wheel weights
photos show correct B tool bar used for right/left tractor mounted plows
 Nowhere near as complicated a tool bar as on a C. One lever plow depth control
Edited by Ken in Texas - 28 Aug 2017 at 6:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 6:16pm
I don't know jack about plows n' stuff, but you guys are amazing with pickin' that sh$& right out! Now ya let all the air out of Richies balloon unless he already knows what he's hookin' up. Looks great from my chair!  LOL!
Steve@B&B
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 7:50pm
Nice work! I'm just starting rehabbing a 3-bottom unit for my WD45.
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 8:23pm
It came off a c parts tractor so your observation   is not a suprise. My question is does it make a difference in terms of plow position and function? I couldn't find a decent B rocks haft but I do have both. A b and c front drawbar and I see no difference in the location of the plow mounts. That being said the rocks haft mount points should be the same as well. Clearly the rockshat fits and the hydraulics match up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 3:49am
It's my understanding that the additional lever, the left hand one and the additional width and complexity on the c rockshaft is for mounting the rear cultivators which I also don't have yet. I suppose I could have taken a cutoff wheel and made this one look more like the b shaft but the mounting holes would still been a little different and close inspection would have revealed it to be a counterfeit b rockshaft. Allthough I could have claimed that it was a prototype :).
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 10:03am
You know, I kind of like the C shaft better than the B.  Expecially for the plow.  The depth lever on the RH foot rest is kind of akward.  Do like the hook C up.  As usual I LOVE the B.  Tractor looks GREAT!!!
Thanks for taking such good care of my favorite.
Good Luck!
Bill Long
PS:  Remember they don't make Allis Chalmers any more so it is not a quick trip to the dealer to get the right parts.  You have to "make do" with what you can get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 12:25pm
From a strictly functional point of view, it will do just fine.  The C liftshaft is prone to getting clothes and fingers caught in the mechanisms, whereas that wont happen with the B liftshaft.  If you do find a nice B lift shaft and depth lever you will need a different connecting link to go up from the plow drawbar to the adjusting lever, as it will be longer and have greater bends in it.
   I'm almost sure if you take a trip to Gettysburg (Yingling's) you could find the proper parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 4:16pm
As anybody who has plowed with tractor mounted plows on a B or a C knows. With each land you plow you follow in the furrow of the previous land with the rear tire and front tire. You may have adjust the  front and rear tread width of your B to the same width as a C to use the C tool bar for plowing.
Being your B has the reversible C wheel centers I presume it also has a adjustable wide front.  By turning the rear wheels around and playing with how the rims bolt up to the centers, you may get the tires to follow in the furrow of the previous land. Both the front and rear tread width need to match and follow in the furrow.
    The C plow tool bar may not work right at all on a B with a Fixed non adjustable narrow tread width.
    See how close the right and left  plows are together on the above B Pictures.
    I wish I had a picture how far apart the plows are on a C with the wider tread width.
    With the rim to wheel center offset you have on the B now, the rear tread width  may be pretty close to what a C tread width is set as narrow as it will go
Edited by Ken in Texas - 29 Aug 2017 at 4:28pm
This page was generated in 0.242 seconds.
