B Oil Filter Experiment
 Post Reply Post Reply Page  <1 2345>
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:02am
Originally posted by Lonn Lonn wrote:
Has the topic has run it's course yet Disapprove
Yes it has Lonn.
Guess again Ermm
Wink
I am a Russian Bot
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:53am
zzeesssh   If it ain't broke what's to fix?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:44am
You assume everything is equal, Gary. Oil viscosity, pump pressure and filter density are three things that can affect pressure. Pressure may or may not indicate increased oil flow to any particular component. There is no pressure bypass on this filter system so any oil that doesn't pass through the filter is sent to engine components. Oil that passes through the filter in this bypass system is returned directly to the oil sump.
Edited by DougS - 14 Sep 2016 at 8:45am
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:06am
Originally posted by WF owner WF owner wrote:
I've been following this thread since the start and have remained silent, until now.
My opinion on this thread is that you guys (maybe one in particular) have changed (hijacked) what was a very informative thread about how different oil filters affect oil pressure on the B engine, to improving oil pressure on this particular engine, then to changing the complete oiling system and finally to opinions on engineers (I worked with engineers my entire career and fixed their mistakes that anyone with an ounce of common sense shouldn't have made...)
If you guys want a new topic, please start a new thread!!! I, personally, was finding the original thread informative, but I am sick of the BS!!!
I understand what you re saying but if you read everything I posted in its proper context from start to finish all I did was post one possible idea and the numbers behind the how and why of it about how the filter issue could have been solved on the engine itself.
No ill will against the AC engineers of the time or anyone who ever owned worked on one those tractors. Just a basic comment on how it could possibly be addressed to work with any low restriction filter.  That was it.
  After that pretty much every post beyond that point was defensive against little more than sheer trolling for sake of trolling.
I didn't start the trolling war but I sure as hell don't give ground to people who have less reading comprehension let alone mental capacity or skills than my own or want to take out their revenge on me for things I have zero association with their design and creation.
Not all engineers are good and not all are bad and just because someone had a bad experience with a design does not mean every engineer or person associated with engneering had a hand in or shares personal responsibility in its being created that way.
If I came here and took out my unending wrath on everyone who's a farmer by attacking them post after post over nonsensical irrelevant made up drivel that does not relate to anything they actually said because I had a runnin with one or two idiot farmers in my life would that be the least bit fair to you or anyone else who took up the career of farming no matter the size of their farm or what they grow?  I don't but that what's been done to me here. Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:09am
Sometimes it's not about fixing something that broke.  It's about keeping things from breaking again or too often.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:32am
Think someone said that the B system filters 15% of the oil flow,would you want to run a
air filter or any other filter that let 85% of the air or oil go unfiltered?
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 1:25pm
Ok I admit it didn't read the entire thread. Too much bickering and technical maubo jumbo.
I just picked up a Hastings LF405 filter and was going to change the oil on my B. Is that a good filter??
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 4:39pm
Just what the heck are you trying to filter out of your engine oil anyway? Rocks, sticks, bugs , corn pollen , or metal shavings?
I have parted out Bs Cs and CAs with good oil pressure that still had antique flat top oil filters on them.
Who ever heard of HIGH DETERGENT 15 40 back in the days of flat top filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 5:02pm
Skeeter - the Hastings is a rebadged Baldwin I believe. Should be fine... Install and at startup see that the gauge reads 10- 15 psi depending on how worn things are.
On the 15% of oil filter question..... the 85% goes to the motor as lube and maintains about 15 psi.. If you installed a BAD filter that has no restriction and lets 40% of the oil go thru it, then you have 60% of the output going to lube and the oil pressure drops to 5 psi which is not good.  There were MANY engines in the 1940s and even later that had NO FILTER. This design was constantly cleaning a portion of the oil. Eventually all the oil gets cleaned. IN this design, if the filter becomes PLUGGED, then you still had oil to all the internals / bearings..... that was a good design in the 1940s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 5:07pm
--There are no "low restriction filters" available. This filter head has a mason jar type screw thread. NOTHING else will fit... Only the CORRECT backpressure filters are available at this time, from several sources..... Wix  SCREWED UP 15 years ago on their filter.. that filter was discontinued.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 5:12pm
notions, bad past experiences, , unrealistic expectations and above all just an ongoing sheer ignorance of what it is they are dealing with and what it is an Applied engineering technicians job deals with.
--so you are basically a technician, not a BSME ?
Edited by steve(ill) - 14 Sep 2016 at 5:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 5:20pm
B oiling system was fine disputes what AC did later create a full flow oiling system that filtered all the oil if the B system had been fine they'd of never went to the full flow system.
--Gary, the bypass filter was a huge advancement at the time. Many engines had no filters at all.  Things change with time and knowledge.. I doubt many would say .. carburetors and distributors are no good because new Trucks use fuel injectors and electronic ignition..... we are a lot smarter now with technology than they were in 1940. .....and I would see no advantage to putting fuel injectors on a B !!
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 6:11pm
Are we sure the bad filters are no longer available?
As of mid 2011 this forum was talking about it.
http://www.allischalmers.com/forum/forum_posts.asp?TID=32327&title=agco-oil-filter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 6:18pm
I'm many things.  Been to college twice now and since you seem so obsessed with me and my life, well......
I have a educated background in Applied Electronics and Electrical Power systems, Mechanical systems and drives, Hydraulics and  Pneumatics systems, Welding Machining and Fabrication plus a fully loaded class A CDL with Hazmat along with a solid background in heavy earth moving equipment operation and service as well.
I'm also good with children, animals and I like helping people while expecting nothing in return but to fairly heard out.
For hobbies I like fixing old machines, doing electrical and electronics projects and metalworking and helping my family friends and whomever else I see fit to need a hand  by sharing whatever of my resources I have that will help them as well.
I was raised by good folk to be good folk and to never be ashamed of my education, knowledge, resources or lack thereof and to always share whatever I have with whomever deserves some help and do so with zero judgement or malice toward them or their life.Wink
As for my friends go they range from young at age to old but young at heart. From poverty level to millionaires and I never judge any of them to be of more or less value than the other regardless of what they do or do not have or where their life took them for any number of reasons.  In my book they are good people and that's what matters most.
The only thing I don't do is tolerate fake people, pompous half wits, idiots, bullies, the greedy and trolls which is probably why you and I don't get along well but really that's not a problem that stems from my end now is it?
If you think figuring out what I am based on what some pieces of paper say go ahead. Obviously it's way more important to you than it is to me or anyone else.   Sleepy
To everyone else I'm quite content with being just another faceless forum member that grew up around farming, old equipment, rural life and good decent people who probably has more questions than he does answers. Smile
Edited by Tcmtech - 14 Sep 2016 at 6:23pm
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 6:25pm
that's fine and dandy but remember Steve(ill) makes double what you make...... LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:23pm
I got nothing against you TCM, but you jumped in here telling everyone how smart you are and its hard for you to discuss topics with us poor dump common folk. You just naturally have a better understanding about EVERYTHING than anyone else in the world.. You told us you were an Engineer and that made you special.. Now you say you are a technician... I really don't care, but that's a BIG DIFFERENCE...
If you had spent more time listening and less time telling us how smart you were, this topic would have been over a week ago and you would be even smarter than you think you are now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:47pm
Why not fuel injection in a B? And engines in cars then went about 50,000 if the owner was real lucky.So why not bring an engine up to date if it can be done cost effectively?
Nothing is written in stone that mechanical things can't be improved as new technology is invented.I like the Idea of a fuel injected B with a full flow oil filter would be pretty cool
and if there wasn't anything in oil to be filtered out no engines would have oil filters and
no need to change oil either.I'd say the full flow oil filter would be more cost effective and probably do more good than the fuel injection, though of course a good D15 engine has the basic improved oiling system the B needed,never heard anyone complain that AC just went too far upgrading that basic engine to the D15 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:49pm
He has yet to actually prove that.
To be honest he has yet to step up and prove much of anything he claims about his supposedly superior self. Confused
What he as proven so far screams  over age minimum wage unpensioned retired  gas station attendant or grocery bagger at a convenience store.  Mall broom pusher perhaps?  Shocked
Could be a Walmart greeter!   I'd drive halfway across the country just buy a 99 cent candy bar at that Walmart to see that!  You never know what those guys are like when they go home and go online Tongue
I'm betting he's really just a Walmart greeter in real life. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:56pm
well you would be wrong "technician", just like you were wrong on most of the posts you have written. Been an Engineer for over 40 years........... but that still has NOTHING to do with common sense on how a bypass system works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:07pm
Okay. Whatever you say.  Clown
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:23am
Let us know the cost of switching a B over to fuel injection and I'm pretty sure I can get you a fairly accurate list on how many conversion kits you would sell. I'll base my estimate on common sense. LOL
Edited by Lonn - 15 Sep 2016 at 6:24am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:34am
I didn't say anything about selling them where'd you get that?If I was looking for cost effective I wouldn't be messing with one to start with and I've seen a whole lot more $$$ thrown into some antique tractors for people's own use than fuel injection would cost.
You make a good point tractors and everything else are built as cheaply as possible to
be able to be competitive in the market place which is fine but it also leaves a wide range of things open to improve performance as can be witinessed at just about any antique
'stock' tractor pull.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:45am
Just making the point that it's not worth doing. Yes Allis could make upgrades because they first off could do it much more cheaply and they could use any improvement as a selling point. In this case with the filter system on a B, it's just plain and simple that the filter maker screwed up and that is that. No need to redesign all the B tractors to fit that filter.
I don't know if this dead horse can take any more beating.Unhappy
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 7:55am
Well, that was a fun read.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:06am
a technician is the guy who has to FIX what the engineer DESIGNED....
yeah, I'm a tech, avionics actually though I ended up designing and building test equipment for the local steel company for 11 years then went on my own doing remote energy control systems of my own hackerproof, design. Haven't had a paycheck in 30 years though I still paid off the house,chop and occassionally buy a D-14 .
hmm..fuel injected B, that's be nice to see...
as far as filtering oil, most small engines(lawn mowers, tillers,snowblowers) have never ever had filters,get abused on a daily basis and STILL run after decades of running....
heck snowblowers don't even have air filters !!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:16am
There is nothing wrong with either engineers, or "techs". Both have necessary functions. For every tech (or farmer) that bitches and bashes on engineers because they're so stupid they put a bearing retainer in a spot hard to reach after final assembly.....there's an engineer who could walk up to a tech with a clean pad of paper and pencil (or new laptop with no information on it!) and say here, design a novel thing, get it through accounting, have it be fully functional and repairable, be marketable,.....etc., I think you guys see the point. I've been on both sides of that pad of paper. Bitched while under a machine in the mud trying to fix a retarded design an engineer made, and I've turned right around and designed something equally "idiotic". It is extremely difficult to think of everything. I think the only way around that is to have one guy do it all, 1 guy builds everything he designed. That would work, but not be very productive!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 10:02am
You might want to consider the Kohler Twin cylinder engines the  KT 17 and 19 HP engines with no filter and no pressurized oiling system were problematic and prone to early failure,then they changed over to pressurized and oil filter with the 18 and 20 HP engines they then had some of the best small engines ever built.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 11:37am
I'd go off the shelf refit from a common fuel injected lawn and garden engine.
Most major small engine manufactures made fuel injected lawn and garden engines in the their larger 2 cylinder size where one of them would likely be a easy refit to the I4 B engine.
An I4 at 1500 RPM is no different than a 2 cylinder at 3000 as far as the control system goes.
The rest is just component placement and fuel mapping and with a lawn and garden engine EFI system designed for an air cooled engine there are way fewer components to work with than what would be associated with a I4 vehicle engine fuel injection system refit.
Infact, Here you go!   Rob the system off this engine!
 ~25 HP plus all electronic governor that would also eliminate that dang throttle sag issues common to 70+ year old engines as well.    (Or is B engine governor sag a taboo issue as well? Shocked
Odds are with a bit of searching a guy could pick one up on the cheap from some lawn care company that had some kid run an engine out of oil and ruin it. Tongue
Edited by Tcmtech - 15 Sep 2016 at 11:39am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 11:58am
No thanks, I have got lawn mowing to do and don't have time to retrofit my tractor with a system that won't make my lawn look any better. If I upgrade it will be to a Simplicity Zero turn.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 5:37pm
Jay
I bought a green (actually silver-colored) lawn mower back in 1989 and it was still going strong when I left it in Oregon last winter. This mover had a Kawasaki engine and an optional oil filter kit. It used an automotive full flow filter which I changed every two years. When I would change the oil it never had a dark dirty look. There was always a glint of the original oil color in the used oil.
I paid $35 for the filter kit and I think I got my moneys worth. To spend several hundred dollars on a retrofit for a very used engine would be not so much worth it.
BTW, I'm shopping for a snow blower right now. Every model I'm considering has an air filter. I don't want fine snow getting into my combustion chamber.
