b model
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Topic: b model
    Posted: 23 Aug 2017 at 2:10pm
I am restoring a 52 b model  I have a carb that came off a 52 wd I believe  any one know if it will work on b model.  also I had a carb rebuilt a couple of years ago and I cant for the life of me remember who I sent it to.  any help on who rebuilds and test carbs I would appreciate   thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 6:14pm
Don't think wd carb will work on a B.  125 cube engine will have a smaller bore than a 226 cube WD...
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 7:12pm
Thanks. I will go ahead and rebuild the carb that came off th b
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 7:27pm
I had a B with a WC carb on it... Bolt pattern was about  1/4 inch wider and manifold had to have holes egg shaped........ main jet was too large...... bore of body was too big... Got it running, but it was not an ideal fit and took a lot of work........ Go with the "B"
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 10:43am
Yep i ordered carb kit today. Thanks fir the reply
This page was generated in 0.210 seconds.
