B Magneto
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Topic: B Magneto
    Posted: 09 May 2012 at 8:23pm
How do I put the magneto in time?
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 11:12pm
scott...there was a post on the forum,not too long ago about this very topic.find it and read it.cant remember who composed it but it was excellent...
outlook6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote outlook6 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 8:37am
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 9:36am
Bunch of good stuff there.  But, do not forget the "finger in the number one cyl" method.  We used it for years.  In fact I did not know there were fire marks on the flywheel till I got on this site.
Set the mag on no one cyl.  Mount in vice and turn till you get fire from no one cyl,  Remove the plug from the number one cyl.  One nearest the radiator.  Turn the engine with finger in hole - plug wires disconnected - till you feel pressure.  When hits top dead center mag linkage should be at 90 degrees.  Couple mag.  Re plug wires. Start tractor.  Fine tune by moving mag on ears.  When right tighten.
Worked for us for YEARS!
I know the other is better but when you are in the field on a hot sunny day this works.
Good Luck!
Bill Long
