B generator
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: B generator
    Posted: 01 May 2022 at 3:28pm
How do I polarize my generator on model B with 6 volt battery and positive ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 4:48pm
The generator has two terminal ..  Field and Armature  "F" and "A"... the "F" is basically the ground ( thru the light switch... So you take a jumper and touch a the HOT terminal of the battery (negative) to the "A" terminal on the generator.. to get a spark ( 1 second).... Note that the BATTERY terminal might go to the amp meter, then out to the CUTOUT switch on the generator... If it is still that way, then you can touch the jumper from the INPUT to the CUTOUT to the OUTPUT or "A" wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 5:27pm
Ok thanks it does have a cut out on the generator and not a voltage regulator
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 5:29pm
Ok does tractor need to be running or not
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 4:59am
NOT running.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 12:25pm
Not meaning to highjack this thread but what if you have a regulator and not a cutout? 6v positive ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 12:47pm
same procedure... You can touch the BAT terminal of the regulator to the G terminal of the reg which goes to the A terminal of the generator..
All you are doing is TELLING the GENERATOR that the "A terminal is to charge to PLUS or MINUS on the battery.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 4:19pm
Thank you! The way I remember is Boy(B) to Girl(G) but never to Female(F). Read that somewhere.
