B fuel related problem |
Post Reply |
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2592 |
Posted: 18 Oct 2018 at 2:23pm |
Went to start my 39 B and after cranking till tired had my wife pull it with her C. Tractor usually pull starts within a couple of feet. No go this time. Open carb drain and get alittle gas draining out. Thought the float was stuck. Tap tap on the bowl nothing. The filter bowl was full of gas and clean. Pulled the gas line and no gas coming out. Found the problem but I have never seen the solution mentioned here. Guess what it was.
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29422 |
Turning the fuel valve on?
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3731 |
no gas in tank?
wfmurray
Orange Level Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Screen in sediment bowel sealed with etyhol gas.
mdm1
CAL(KS) got it. Went and found a universal fuel gauge (aka the first stick I found) took a walk, got a gas can, put it in the tank. 2 cranks later started up. Drove it to the shed and put away for the winter.
Post Reply | |
