B front main seal off BUT |
archangel_cpj
Topic: B front main seal off BUTPosted: 07 Apr 2018 at 6:21pm |
The seal had been replaced once it looks like so no clue why the modern seal failed... why is the shaft not smooth???
On a plus the pulle came off 8n my hand LOL ![]() Edited by archangel_cpj - 07 Apr 2018 at 6:22pm |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 07 Apr 2018 at 6:35pm |
From the factory these tractors had a seal that I believe was several thin pieces of cork sandwiched together, at least that's what mine was. The cork kinda just slows the leak rather than completely seal it, so the spiral you see is meant to push the oil back into the motor when it's running. That will not work with a new modern rubber lip seal.
My B was an earlier model and used a smaller diameter seal, so I used a Dremel tool to bore the hole out a bit bigger for a modern seal. What I did to fix the groove was make it all nice and clean, fill it with JB weld, let it cure, then file/sand it down until it was smooth. Allis B/C/CA expert Dick Lemmons here on the forum advised me that, and while I was doubtful at first, it worked great and has been leak-free for almost 2 years. Since the seal rides on the metal crankshaft, it won't wear down the JB Weld.
Gerald J.
Posted: 07 Apr 2018 at 7:56pm |
Joined: 11 Sep 2009 Location: illinois Points: 90846 |
Posted: 07 Apr 2018 at 8:35pm |
wire brush all the paint off... and sand the surface with sand paper then wipe off with acetone prior to installing the JB weld into the groove.. then sand down smooth.
CrestonM
Posted: 07 Apr 2018 at 8:39pm |
Also, if you'll take a small pick and clean out the groove that way, it will help remove anything the acetone doesn't get out. After 70 years, there could be some stuck-in stuff.
archangel_cpj
Posted: 07 Apr 2018 at 9:28pm |
THANKS my dad is in fiberglass so acetone is easy.. I thought that was the groove but wanted to make sure.. I can't believe that pulley came right off...
CrestonM
Posted: 08 Apr 2018 at 12:13am |
You might check your crankshaft key and make sure it is alright, or even go ahead and replace it anyway. Mine came off really easily as well. Turned out my half-moon key was shot. It was so worn, that if it went much longer it would probably have sheared the rest of the way off.
archangel_cpj
Posted: 08 Apr 2018 at 8:42am |
Yep its shot gonna add a new one any idea on size or do I wing it
