|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| B front hydraulic pump size |
| Post Reply   |
| oldways   Orange Level   Joined: 25 Apr 2013 Location: west Ky Points: 509 |  Post Options  Thanks(0)  Quote  Reply  Topic: B front hydraulic pump size Posted: 17 Jan 2023 at 11:22pm |
   I'm planning to add front mount pump for live hydraulic to my B. Can someone tell me what size gear pump to order ? I'm looking getting one from surplus center.  Looking  at GP series pumps. Need to know what displacement to get. Thanks .
     1 Corinthians 1:18  1969-190xt-III.  1966 190xt gas.  1966 190xt Cab.  1948-G. 1937-WC unstyled. 1950-B. 1951-CA. 1966-D17-IV
| DiyDave   Orange Level Access     Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54402 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 5:06am |
   Go to their tech page.  Remember that a B has only about 20 hp. I'd say you want ine that draws no more than 10 HP, 1500 PSI, around 5-10 gpm... Just my humble opinion...   | |
| AaronSEIA   Orange Level   Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 5:50am |
   What do you want to do with the pump?  Thats going to determine what size you'd need.  I'd say 10 gpm and 2,000 psi would catch it. AaronSEIA | |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 6:00am |
   What diameter of cylinders do you intend to use?? Anything a model B could handle would only need less than a 2 inch diameter cylinder, so 4 to 5 GPM would be plenty.
| oldways   Orange Level   Joined: 25 Apr 2013 Location: west Ky Points: 509 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 8:51am |
   1.5 -2. Bore. Lift grader blade and belly mower. Currently use stock pump aftermarket cylinder. 3 point conversion. Works ok just not live and when grading driveway it's terribly aggravating and borderline dangerous.  Have to stop in highway get blade up , tractor back in gear. Etc. Usual downfalls of not having live hydraulic.
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 9:00am |
   Well, an old D-17 is only 4.5 GPM, so a "B" can't hardly be more than 2 GPM's.
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88509 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 9:01am |
   rear pump is measured in QUARTS per minute.. Very small... Think of a 5 gallon bucket. If you pump that much in a minute, that would be PLENTY !.
 for SIZE... lets say you want 2 gallons per minute... there are 230 cubic inches in a gallon , so you want about 500 cubic inches pumped per minute....  Your motor is running at 1500 rpm, so you need about .33 cubic inches displacement per revolution of the pump... Look for pump sizes in the .31 to .36 displacement ( approx). just make sure you get the right rotation... click on the pump and look at the rotation, speed and pressure rating... most of those pumps can put out 5 gpm at 3600 rpm... your running less than half that speed....... too big of pump and your "raise" speed will be too fast. Edited by steve(ill) - 18 Jan 2023 at 9:20am | |
| Les Kerf   Orange Level   Joined: 08 May 2020 Location: Idaho Points: 1384 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 12:46pm |
   An electric /hydraulic snowplow pump would be more than adequate for this task and much easier to hook up. | |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 3:20pm |
   I agree Les. So many of these tractors have been converted to 12 Volts with an alternator anyway.
| oldways   Orange Level   Joined: 25 Apr 2013 Location: west Ky Points: 509 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jan 2023 at 8:04pm |
   Thanks for the help guys!
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
