B cylinder vs. WD cylinder
yochujr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Topic: B cylinder vs. WD cylinder
    Posted: 16 Dec 2010 at 10:16pm
Anyone know how difficult it would be to get a WD lift cylinder to work on a B?  Right now, I'm faced with possibly needing 2 B cylinders and thought a single WD might provide me with the needed lifting power if it will fit.  Any input is appreciated.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 1:53am
WD cylinder is way longer. Depends how handy you are at fabricating.
 Will it fit right on?   No.
 Can it be made to work?   You bet.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 3:10am
It will be a lot slower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 8:15am
you have to take the WD45 cylinder apart, cut 7 inches off the rod and barrel and "fabricate" it back together. It is 20 inches long and the B is 13.... OR you have to relocate the ancor pin under the axle  and way forward instead of on top of the axle by the seat frame.. the WD will have the power of  2-3 of the B cylinders .. will be slightly slower, but not really noticable... its a project.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 9:30am
There might be something at Surplus Center that would be closer to the B cylinder and save much fabrication.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:08pm
Thanks.  I looked on the website you suggested and there seems to be some 13" long cylinders with a 6" stroke.  I need to go out and take some measurements to make sure that's going to give me the lift I need.
The cylinder that came off the tractor was a 2" bore and seemed a little close to the frame towards the front.  Does anyone know if a 1 1/2" cylinder will be enough to lift my 3-point or should I try to squeeze a 2" back in.  Wasn't sure about fluid capacity on the big cylinder either.
