B Cylinder pressures
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: B Cylinder pressures
    Posted: 31 Oct 2010 at 12:20pm
What is the standard pressure test values?
Engine has good power and doesn't smoke except for a slight puff at startup.
I'm looking at some down time and was looking for things to do and working on the B is therapeutic. Thought about checking the bores getting the head checked. Might need my head checked since it runs good as is.
Charlie
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 12:29pm
If you get 125 you are doing good.
A slight puff of blue smoke at start-up sometimes is just some oil coming down the valve guides.
To do a good test get the engine hot.
Remove all spark plugs.
Gas shut off. I shut off the gas and let the engine drain the carb and stall before the test.
Choke and throttle wide open.
Air cleaner unhooked.
Give each cylinders around 6 revs for the test.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 12:30pm
pressure isn't the important thing it isthe variation between cylinders that is . You can have loss of compression across all cylinders showing normal wear but when a large difference shows between them , problem needs to be found.
Edited by Coke-in-MN - 31 Oct 2010 at 12:58pm
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 12:50pm
Right, If you have 10-15 lbs differance between any cylinders it is time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 3:50pm
I split the tractor today to replace the throwout bearing only to find I was shipped a D12 bearing, the B is much smaller! Time to re-order.
I also removed the radiator as I had a slight drip from the upper neck, looks like the weld cracked. Need to find a local repair shop to have them fix it.
Cold I got 90 psi on 3 and 89 on 1. All the plugs look normal so no oil burning. My pressure gauge must be off as on my motorcycle it reads lower than normal also.
I also noticed the governor rod was hitting the belt drive and it had rub marks on it so I tweaked the rod a little to get it to clear. Now the carb goes from stop to stop with no interference. Maybe I will get full power now :) not that I thought it was lacking before.
I like the simple nature of this tractor!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 4:12pm
They look ok. 90 is low but if you do it again with a hot engine you will see better reading.
Cold tests are always wrong.
The good thing is they are all equal.
Anything below 90 I would fix.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:33pm
That is a little low on compression.  Not real bad, but wil make it a little harder to start and have a loss in power.  Put some oil in the cylinders, and see if the pressure numbers come up.  If so, the rings/pistons/cylinders are the problem.  If not, the valves are suspect.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:42pm
Maybe you should have your head examined. LOL Now you done it Charlie. Ya got me thinkin I should check my B. Well it might not get done this year cause it's in the neighbors shed a mile away and the coolant has been drained.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 9:08pm
it fires right up now, I can't imagine it being easier to start.
I'll check the valve settings as I'm sure they haven't been touched in years.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 9:21pm
Mine too. Almost always on the second quarter turn of the crank, unless I forget to flip the kill switch to the run position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 6:15am
How worn do you let the fingers on the pressure plate get worn down?
Oh and the bearing was toast but the clutch pack looks good.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 7:19am
10% variation is one sign of problems coming. Another way of checking is to use air into cylinder through spark plug hole , listen for air at carb for valve problems, breather for blow-by problems.
tractorkid1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorkid1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 8:29am
I always liked using the cylinder leak down method insted of a compression gauge reading. The leak down test tells you more information as long as youlook and listen to where the air is coming out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 7:20pm
Kudos to Scholtens Equip.
I emailed them today about the bearing and they are overnighting me a replacement free of charge! Great service.
Now I have a 2.5" ID x 4" OD throw-out bearing if anyone knows what it goes to and can use it.
Charlie
