B/C wiring?
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Topic: B/C wiring?
    Posted: 28 May 2018 at 6:22am
Anyone have a simple wiring diagram for converting a B/C 6 volt wiring system to a voltage regulator instead of the cutout relay? Thanks, Mike.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:23am
someone will post, just be sure to replace 100% of the exisiting wires ! ALL of them..then she'll be good ofr the next 50 years !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:33am
Image result for 6 volt regulator vs cut out relay wiring
The cut out system has the field from the generator going to a resistor on the original light switch. Low charge is through the resistor, and the resistor is bypassed straight to ground when the switch is pulled out for lights or for full charge.
http://www.yesterdaystractors.com/eg3bvr.jpg
The regulator system has the field going to the regulator, eliminating the need for the 3 position switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2018 at 7:37am
Thank you Mr. Tucker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2018 at 8:09am
  Thumbs Up
