B/C rod alingment
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: B/C rod alingment
    Posted: 26 Dec 2010 at 9:39pm
I've got my C and B sitting beside each other doing a transplant of one good cylinder from the B to the C.  I noticed that some of the rods are installed with the piston pin bolts facing right, some facing left.  Both engines are like that and both have been apart with the rods numbered.  Perhaps it doesn't matter but shouldn't they all be facing the same side?
Hey Miles, what's the latest on your C compression problem?
Allis Express participant
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 9:48pm
No,  they have to be reversed because of the offset for the bearing journals.
On some engines, like the 201 & 226, they all face the same way. The bolt on the same side as the cam. Bob
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:36am
the short side of bng goes toward the main bng.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:52am
That is correct for the B and C engines, as the others mentioned.  Here is a picture of how they go, you can see the short flange on each rod will be closest to a main bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 11:29am
Thanks everyone, especially TomMN for the pic.  Progress!
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 12:40pm
John Cylinder 2 and 3 look like they haven't fired for years and the Valves were rusted ojn the cylinder side. I have cleaned them up and resurfaced them. Starting to put them back together today. Need to have the Head ready to go back on when I leave on Thursday... What size oil filter do I need to buy for the 125? The oil pump was basically pumping oily sand into the Head... lol... I must say I haven't taken care of this one as I should...
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
