B/C rims same as Cub, right?
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: B/C rims same as Cub, right?
    Posted: 24 Mar 2010 at 8:58am
Can you guys confirm for me that other than the mounting method, Farmall Cub rims are the same as B/C rims?  Or is it the slightly larger Farmalls that have the same rims?  Thanks in advance.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 9:25am
Use the rims off a A or B farmall. The Cub rims are narrow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 9:33am
Thanks Kip.  Narrow, but will they still bolt up?  Just thinking of making my parts C functional, not perfect by any means.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 9:51am
Checking sizes in Steiners catalog, the Farmall cub rims are 12" and have a 3 1/8" pilot hole and bolt spacing is 2 3/4" cc.  The Allis B, C rim is 15" and has a 2 3/4" pilot and a bolt spacing of 2 5/8" cc.  Looks to be not interchangeable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 10:42am
Sorry, I should have said rear rims.  Thanks.
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 10:52am
I have two allis B/C rear centers that have A/B farmall rims on them.  See a lot of them since the allis rims are harder to find and more expensive in this area.
This page was generated in 0.320 seconds.
