B/C Hydraulic Pump Question
eastwold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eastwold Quote  Post ReplyReply Direct Link To This Post Topic: B/C Hydraulic Pump Question
    Posted: 21 Aug 2020 at 12:24pm
I have an old B with belly mower which works great. The hydraulics raise and lower the deck fine but the deck tends to settle over time. I believe the pump and cylinder are original equipment and there are no leaks visible.  So I wonder if anyone can steer me to more info on the pump and how it works. Is there a one way valve that has failed or a seal in the control mechanism that has failed, etc? It is getting new final drive parts at the moment, so the pump is pretty easy to get at and it may be a good time to work on the settling problem. I have not yet removed or inspected any internal parts of the pump. Thanks in advance for any advice!
Eric Eastwold
Spring Valley, MN
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:49pm
The pump does not have a hold valve. It is normal for the cylinder to settle over time.
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:58pm
That’s what my B does with the plow on it too.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 9:01pm
The pump is a lifting device not a holding device.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote eastwold Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 4:49pm
OK, Thanks all!
