B/C exhaust manifold |
MikeinLcoMo
Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
Topic: B/C exhaust manifoldPosted: 06 Dec 2019 at 3:31pm |
Anyone remember the discussion about threading the exhaust manifold for installing a threaded pipe to aid in keeping rain out from running down the muffler? I think it was just a few weeks ago but I can't seem to find it. Thanks, Mike.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 06 Dec 2019 at 5:47pm |
1 1/4 taper pipe tap for a 1 1/4 nipple.
![]() Edited by Dick L - 06 Dec 2019 at 5:50pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54423 |
Posted: 06 Dec 2019 at 5:50pm |
Easiest way to find things, is to type Allis Chalmers forum, followed by the subject you are searching, into Google, and search. that's how I found this one:
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 06 Dec 2019 at 6:07pm |
I remember something about rain caps not keeping water out of manifold. And suggestions on tapping and a brazing, and a modification with exhaust piping.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 06 Dec 2019 at 6:21pm |
The threads help for a while, but eventually let water in! --- easiest way is to braze an upside down funnel above the manifold on the muffler pipe. --- did this on a 806 and a couple other tractors, does work.
Dick L
Posted: 06 Dec 2019 at 6:51pm |
That is why water pipes always leak right! |
Joined: 11 Sep 2009 Location: illinois Points: 88586 |
Posted: 06 Dec 2019 at 7:05pm |
if you thread the pipe into the manifold, and still get some water........... It is coming down the exhaust pipe thru the muffle......... the pipe thread don't leak.
MikeinLcoMo
Posted: 07 Dec 2019 at 7:50am |
Thanks guys.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 07 Dec 2019 at 8:13am |
I agree with ac fleet. Not the easiest thing to do though.
I wonder, has anyone ever tried Gorilla glue to do this? Can it withstand the high temp? |
GreenOrange
Joined: 11 Sep 2009 Location: Wisconsin Points: 851 |
Posted: 07 Dec 2019 at 9:32am |
My preference is to buy the OEM style of muffler which shields that area, then cover the exhaust pipe with a rain cap or can when left outside.
Dick L
Posted: 07 Dec 2019 at 9:43am |
I did the shied over the manifold opening around the internal muffler pipe thing until I picked up my 1 1/4" taper pipe to see what size drill it would take to ream it out for the tap. I found it is cast to the correct diameter. All the Oliver's I grew up using came from the factory with a threaded pipe nipple that the muffler pipe slid over. The pipe nipple is a one time deal for the life time of the tractor with a (proper) rain cap. All my tractors set out year around and some only get started every couple years or longer. It is my insurance policy. |
Ted J
Posted: 07 Dec 2019 at 10:45am |
Any idea what muffler number you use Dick?
Dick L
Posted: 07 Dec 2019 at 12:39pm |
The one I use is a Ford inline under the red belly. I took a 1 1/4" nipple from their stock with me to the mufflers at Rural King and found one that fit and then put the nipple back. I cut and thread my own nipples at the factory. |
MikeinLcoMo
Posted: 08 Dec 2019 at 10:31am |
Farmall Cubs use a threaded pipe into exhaust manifold.
