B brakes
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: B brakes
    Posted: 14 Jun 2020 at 5:49pm
Has anyone installed hydraulic brakes on a B?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 6:52pm
Why ? The original brakes work pretty well.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 6:34am
I thought about it a while back. I only wallowed it around in my mind. In my mind I came up with a way to mount a cylinder at brake bands. Master cylinders would not be a problem mounting either. What was my reason for doing so? To be different because I have an active mind that is different and that is my golf or sitting in a bar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 6:53pm
I think the brakes would easier to use as not as much force on the brake peddle, also the peddle would not travel as far.  My B stops pretty good moving forward but not so good in reverse.  My yard has some inclines in the back that I need to back down and drive up forward to mow,  sometimes stopping going backward down hill becomes a challenge to get enough pressure on brake peddle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 6:59pm
DickL, I'm kinda mulling over using 2 brake master cylinders, 1 for each side,, and either a short hydraulic cylinder, or have begun thinking of a way to mount regular wheel cylinders, just in the thinking stage currently. Thanks, Tim
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 8:25pm
All you really need is a GOOD material to stop the tractor and most of what a person gets any more is the foreign junk. If you want some good material installed on your brake bands, then contact me and I'll take care of that problem for you. Have sold many brakes to folks and never a problem with the good stuff...Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 10:11pm
I agree with Rick.... its not that you need MORE PRESSURE.. your just going to break something... What you need is BETTER LININGS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 5:41am
It is silly to take a perfectly good B and lower it and make it so you can't really farm with it. Or to put a V8 engine in one.
If you don't have a problem with doing the above then why would you have a problem with putting hydraulic brakes on one.
It is using your mind to create something to prove to yourself you can do it for one thing.
Actually that kind of thinking is how improvements were made to the C to come up with the CA.
I personally applaud anyone that thinks out side of the box when working on anything. They were the people I tried to hire over the years in my factory. The problem for me was those people are always looking for a new adventure and were gone in a few years. Which is really a good thing for them to broaden their abilities.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 8:34am
Nothing wrong with a good imagination Dick........ the problem is thinking that will FIX a bad set of brakes.  If you cant stop a B with FOOT BRAKE PRESSURE, then you have a brake lining problem.......... I modify things all the time.. but you have to start with GOOD parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 8:53am
Well, that kinda' fits me quite well. Always comin' up with somethin' different. Like Dick says, keeps the mind sharp! Nuttin' wrong wit' dat! My Antique cars as well as my Tractors all have somethin' different bout' em'. Some small upgrades or improvements, some large improvements. My wiring systems are the same way...  LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 4:28pm
Well forgive me for asking a simple question, I won't bother you guys again with any thoughts of modifications.....................................................
Thank you, Dick L and Steve in NJ for supporting thoughts of making changes!!!!!!!!!!
Edited by TMiller/NC - 16 Jun 2020 at 5:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 6:51pm
Hey, If you don't post about them I won't be able to see ideas from a like minded fellow. On the open internet you can't cut your fingernails without someone saying your doing it wrong. We gotta love them also.
Edited by Dick L - 16 Jun 2020 at 6:52pm
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 11:29pm
I've thought about that one too.  I was thinking more along the line of a small disc brake setup to replace the original drums. Then, if a small enough caliper, the whole assembly could fit in the original cavity.  Might be worth talking to Wilwood to see if they're interested in making a conversion.  They make custom brakes for many applications and they're USA made.  Maybe look at also getting a conversion made for the notorious WD/WD45 brakes.   Get Steve working on this through B&B!! LOL
Edited by Alberta Phil - 16 Jun 2020 at 11:31pm
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 10:02pm
A B with fresh linings stops pretty good. If ya have a later B they are foot brakes and pretty darn simple. Now the problem I have is keeping the darned mice out of there. They seem to think it is an attractive place to live.
