B and CA fuel tank interchange (?) |
Post Reply |
cdon_FL
Silver Level Joined: 15 Aug 2016 Location: NE Florida Points: 116 |
Posted: 05 Dec 2016 at 12:19pm |
The fuel tank on my B has gotten pretty leaky. Has been patched with JB in the past and red-koted, too. Still leaking at anything over 1 gallon or so.
Not sure where to go from here. Will a tank from a CA fit on my B? Both are from the early to mid 50s. Any good sources for reproduction tanks (?) |
Chris in NE Florida
Jhebel
Silver Level Joined: 21 Oct 2015 Location: York Co, PA Points: 66 |
CA tank should fit.
Ken in Texas
Orange Level Joined: 11 Sep 2009 Location: Henderson, TX Points: 5915 |
Any B/C/CA gas tank with a strap fastener on the top rear of the tank is a direct replacement any way you go. No Reproductions are being made.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
As long as both tanks have the strap with bolt on the back, the CA tank will fit on your B or C. A B or C tank will NOT fit on a CA becasue the starter switch on a CA needs an indent on the bottom of the tank.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Alex09(WI)
On a side note, in would be profitable for someone to make plastic or resin replacement tanks becasue I easily get $100 for a used B/C/CA tank on ebay (in great shape)
www.awtractor.com
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5082 |
I saved a real bad tank for my C with fiberglass mat. I sanded the tank to bare metal, then cut strips of mat, soaked them in resin on a plastic bag over a plank, laid the strips on the tank
tight without over lap. when cured I sanded smooth, then coated with a thin coat of bondo. (I put a small amount of the resin in the bondo mix) I then sanded, primed and painted. That was about six years ago.
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Jump over to the YT Site, Allis Chalmers in Classified Ads, Pictures.
A fella named Paul in Wentzville, MO parts out the B, C and CA specifically and lists many available parts. Have bought from him previously and he is a straight shooter. Any of his ads (he usually runs many) will have his contact info and this guy deals in plenty of parts. Tim |
Sandknob
Orange Level Joined: 12 Sep 2009 Location: Oblong, IL Points: 2456 |
I'll have a B gas tank shortly if you need one.
Bill Deppe/AC Salvag
Orange Level Access Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 968 |
Have a couple that have been cleaned.
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1702 |
Doesn't the CA tank have a depression in the bottom for clearance of something, can't remember what.
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1446 |
Starter
Ken in Texas
actually the top mounted hand operated starter switch makes the dent on the bottom of the gas tank necessary on the CA AND late Bs and IBs
sparky
Starter
kelso
Bronze Level Joined: 07 Jan 2020 Location: Port Ludlow, WA Points: 42 |
Does anyone still have a gas tank for a AC model 1949 C ? Thanks, Tim
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
Instead of bring up an old thread, go to the classified section and make a new post. You'll probably get a quicker response if anybody has one for sale. |
Gafry53
Bronze Level Joined: 27 Oct 2020 Location: Ephrata,Pa. Points: 16 |
Just bought a model C with leaking tank how much for tank ?? gafry737677@gmail.com
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5155 |
Gafry Most of this Post is about 4 years old. I think you would be better off starting a New post in the Classified Section with a Subject Wanted-Gas Tank for a 'C' G |
Post Reply | |
